What's wrong with AFR's exhaust port? >
Old 03-05-2015 | 06:33 PM
  #131
yup,,afr has great packaging.our ups driver doesn't do that kind of damage.
sutphen 30 is offline
Old 03-05-2015 | 06:49 PM
  #132
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I think somebody was pissed at the 70 lbs . Box looked like it had bacca spit on it too . Makes me wonder if these went through Michigan on the way here .
the deep is offline
Old 03-05-2015 | 07:21 PM
  #133
Originally Posted by the deep
Someday in the future , a man like myself that is researching Air Flow Research heads in particular the 315's for his build , needs to see these pics . Got a present from Marine Kinetics today and took these pics straight out of the shipping box . A picture does speak a thousand words !!! Straight down the exhaust port with an Inconal Tulip Valve at the bottom .
Combustion chamber almost looks hand polished .
Intake side of things .
And I wanted to add that only a top notch company would package their product in such a manner to protect it from careless UPS employees . The damage shown here would have surely resulted in a damaged aluminum head .
Man those pics almost make me want to pull my 385's out of the box that's been sitting in my living room for a month.
Black Baja is offline
Old 03-05-2015 | 07:25 PM
  #134
the deep's Avatar
Fast Singles Club
Definitely look better in the living room out of the box .
the deep is offline
Old 03-05-2015 | 08:36 PM
  #135
Full Force's Avatar
Got my AFR yesterday, Same quality, I did CNC chamber not full port, but extremely happy with product and the way they were bolted down inside box..
[ATTACH=CONFIG]538076[/ATTACH][ATTACH=CONFIG]538077[/ATTACH][ATTACH=CONFIG]538078[/ATTACH]
Attached Thumbnails What's wrong with AFR's exhaust port?-afr-cnc.png   What's wrong with AFR's exhaust port?-afr4.jpg   What's wrong with AFR's exhaust port?-afr5.jpg
Full Force is offline
Old 03-05-2015 | 10:05 PM
  #136
Randy Nielsen's Avatar
[ATTACH=CONFIG]538079[/ATTACH][ATTACH=CONFIG]538080[/ATTACH][ATTACH=CONFIG]538081[/ATTACH]A few pics of my new AFR's
Attached Thumbnails What's wrong with AFR's exhaust port?-2015030595113359.jpg   What's wrong with AFR's exhaust port?-2015030295125915.jpg   What's wrong with AFR's exhaust port?-2015030295163551.jpg
Randy Nielsen is offline
Old 03-06-2015 | 05:25 AM
  #137
That's a pretty good looking cast port.
Old 03-06-2015 | 10:25 AM
  #138
When you buy the AFR heads ready to bolt on, are the guide clearances and seat widths set up for marine/marine supercharging ?
MILD THUNDER is offline
Old 03-06-2015 | 11:39 AM
  #139
the deep's Avatar
Fast Singles Club
Although they say nothing about seat widths they do mention vgc in the literature as follows : Our typical valve guide clearances are .0013 - .0016 . In some severe applications ( nitrous , marine endurance racing or blower usage ) looser guides might be required . Check with your engine builder .
the deep is offline
Old 03-06-2015 | 12:44 PM
  #140
That seems a little tight for a marine supercharged setup esp running cool water temps . Id be a little worried about being that tight, especially if your engine isnt thermally stable. If your on the cold side of water temps, that may exacerbate the issue. Also, inconel valves are great but they still need a wide seat to aid in cooling the valve .
My next set of heads I will be buying bare and having my head guy assemble them, check guide clearances, check valve job ...
