On & off slight vibration at cruise >
Old 09-05-2002 | 09:35 AM
Whiteknuckle's Avatar
Default On & off slight vibration at cruise
I just reinstalled the engine a few weeks ago after doing some upgrades. Heads, cam, intake etc. All the Marine accessories were off, and reinstalled. At about 3000 RPM a slight vibration is felt in the boat and in the steering wheel that comes and goes in almost a rhythm. It will vibrate maybe 5 seconds, then off 5 seconds. When I feel the vibration the exhaust note also changes slightly, although there is no noticable change in RPM or speed. Any ideas?
Whiteknuckle is offline
Old 09-05-2002 | 09:55 AM
Iggy's Avatar
Single or twin?
If you have twin engines, it's could be a synchronization problem.
If it's a single, check the drive alignment, might be off. Re-tighten all the engine mounting bolts, they could've loosened with the vibration. Drive attachment bolts too.
Iggy is offline
Old 09-05-2002 | 10:17 AM
It is a single. Would the coupler show those symtoms?
Old 09-05-2002 | 03:02 PM
HyperBaja's Avatar
an engine will have bad harmincs at certain rpm's, it being in a rhythm does seem weird. meybe something loose in the drive?
HyperBaja is offline
Old 04-20-2003 | 05:57 AM
Keith's Avatar
CBPBA's Walmart Greeter
White Knuckle, did you ever find the fix for your problem? What was it?
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
CigDaze
12-11-2006 07:14 AM
unimog1300
1
03-12-2006 06:39 PM
28Profile
4
06-30-2005 06:41 PM
RMM
7
05-23-2005 10:03 PM
