Oil filter... >
Oil filter...
Oil filter...
Old 03-15-2015 | 05:06 PM
  #101
also can have Napa made up hoses. Regardless of what route you go I'd just be very certain everything is plumbed correctly and good and secure. Stay away from barbed fittings with clamps. I treat those lines like a doc does main arteries during heart surgery.
getrdunn is offline
Old 03-15-2015 | 06:24 PM
  #102
14 apache's Avatar
High quality push lock will be more than adequate for any oil system the only thing you wont find is a sweeping bend. Think -10 is around 250psi working pressure. And in salt water it wont corrode fittings and crack.
14 apache is offline
Old 03-15-2015 | 06:31 PM
  #103
vintage chromoly's Avatar
I called barnes to confirm the oil line size for the supply side of my dry sump system (out of the pump, filter, oil t-stat, oil cooler, and into the block).
They told me to use -12 and not to even think of using smaller than that. I talked to a hydraulic engineer there, not a kid on a tech line.
Maybe it's different on a wet sump system.
vintage chromoly is offline
Old 03-15-2015 | 07:00 PM
  #104
i always plum the oil system with -12 but -10 will also work.
mike tkach is offline
Old 03-15-2015 | 09:39 PM
  #105
3 pages later I`m still not sure if the 51222R WIX filter I use is a good one.
Made with a full metal base plate for superior strength at the double seal & also feature a silicone anti-drainback valve. Glass-enhanced media in WIX oil filters offers greater efficiency, capturing more 10 to 12 micron sized particles than other cellulose/synthetic blend medias. Use PART NUMBER drop down to select filter.
Suthen 30 I notice you rip on Csraub quite a bit .. any reason?
ICDEDPPL is offline
Old 03-16-2015 | 07:55 AM
  #106
apollard is offline
Old 03-16-2015 | 08:12 AM
  #107
Rookie's Avatar
I believe it goes back to "soda pop camshafts","1adamb" thread from Speedwake, water pump engines from reversion and 690HP peanut port 454's. That's what I have gathered over the years.
Rookie is offline
Old 03-16-2015 | 09:01 AM
  #108
thatand he fckd me on 5 sets of lifters and I was sent his retarded spread sheet he uses for designing cams,,which always have tuning issues,valve train issues and generally come up short on hp.plus the dick can't even change his own intake.
Then what reallly sealed the deal is when he came on and said just swapping out an intake netted 30hp.turned out a ton of other things were changed at the same.SB,B2B(born to burn) got pooched.and then there are the 20-30% correction factor dyno sheets,,,and on and on.
I just don't want anyone getting taking by the con man.he can sure talk the deal and come off as a nice guy,,till theres a problem and its always Your fault.
sutphen 30 is offline
Old 03-16-2015 | 11:16 AM
  #109
Originally Posted by thirdchildhood
So all of the past oil filter threads heavily endorsing Wix (which I use) are . . . . . . . . . wrong?
They aren't wrong, WIX makes a great product, however there are more capable filters out there. The WIX racing filter flows 28-30gpm, however do we really need that? Many never pose this question.
Borgie is offline
Old 03-16-2015 | 01:28 PM
  #110
It`s interesting different forums and their dynamics. He is to performance boats.com what Bob-0 is to OSO. the go to guy.
Those guys over there don`t do any pleasure boating, mostly all racers, GN7 (RIP) was a big fan and that guy knew his $hit.
It is what it is I guess
ICDEDPPL is offline
