Oil filter... >
Oil filter...
Oil filter...
Old 03-09-2015 | 09:29 PM
SB
Originally Posted by SB
What was used to cut the filter open ?
Originally Posted by Baja Rooster
Will do. There's kitty litter on it and I cut it open with a metal sawzall blade.
And that's why I asked. The metal appears 'ripped' and the top of pleates the same (ie:'ripped' too), making them look horrible. That skews the picture we see. IE; if it was cut by by an oil filter cutter or similar it would not look the same.....and that's the difference that makes it impossible, IMHO, to judge anything by looking at that pic. Probably just as hard in person.
SB is offline
Old 03-09-2015 | 09:33 PM
BUP
You need to use an oil filter cutter tool so you do not get all those very fine metal shavings (metallic color) all over the pleats and down in the filter from cutting open with a sawzall or cut off tools. We use oil filter cutters all the time and to cut open all fuel filters to.
Plus the oil filter cutter tool cuts off just above the base, Not jagged cuts into the pleats
BUP is offline
Old 03-09-2015 | 09:54 PM
SB
Good pic of more properly cut open filters:
1st, a typical filter cutter, although many other styles....pretty much all styles use rolling cutting wheels like a can opener:
SB is offline
Old 03-09-2015 | 10:10 PM
Ah yea, in light of that the sawzall hack isn't going to help much. ��
Baja Rooster is offline
Old 03-09-2015 | 10:12 PM
14 apache's Avatar
Originally Posted by Black Baja
That is a very cheap filter. What kind of oil are you using? It looks cheap also.
Why does it look like a cheep filter? Looks like a GM or Mercruiser Plastic insert? How to check for cheep oil?
14 apache is offline
Old 03-09-2015 | 10:22 PM
SB
By looks.
LOL !
Sorry Black Baja. That part was funny !
SB is offline
Old 03-09-2015 | 10:28 PM
This is the oil in it now.
Old 03-09-2015 | 10:31 PM
14 apache's Avatar
Your problems I don't think are oil related. The oil filter is collapsed. Look for brass if none run it again and check oil filter.
Old 03-09-2015 | 10:47 PM
Kinda tough to tell if it is actually collapsed after murdering it with a sawzall, but I suspect it was as I have a ZZ502 cam with OEM manifolds so it was definitely sucking water. It was a mercruiser filter though.
The bummer is I have a tubing cutter good for that size. Bummer.
Old 03-09-2015 | 10:58 PM
14 apache's Avatar
No doubt that its pushed together. Just look at the rest of the filter. Are you salt water or fresh?
