What to use to glue the cockpit sole down? >
Old 03-15-2015 | 11:07 PM
Default What to use to glue the cockpit sole down?
Doing stringer work. Then will need to glue down the floor. Typically I see manufactures use a pink hard chalk like substance with a look of body so it can fill up to 3/4" gaps. Anyone know what to use?
cyrus77 is offline
Old 03-16-2015 | 07:19 AM
Ayuh,..... Thickened resin,....
Bondo is offline
Old 03-16-2015 | 05:36 PM
Not sure if I can thick resin to stand up that much...
cyrus77 is offline
Old 03-17-2015 | 08:55 AM
Ayuh,.... Sure ya can,... I make putty all the time,.....
Just add alittle ground glass, maybe some glass fiber, then thicken with cab-o-sil til it's a putty,.....
The deck, should be pretty much restin' on the stringers, Before ya glue down anything,.....
Bondo is offline
Old 03-17-2015 | 09:20 AM
That or West System 404
chrisf695 is offline
Old 03-17-2015 | 10:21 AM
if you never want to remove 3M 5200
ezstriper is offline
Old 03-17-2015 | 01:22 PM
BUP
many boat builders use the link below and I know at one time and possible still one of their bonding adhesives was pink
http://www.itwplexus.com/industries/marine.cfm
BUP is offline
