Carb opinions 540's 700 hp... >
Old 06-12-2015 | 02:14 PM
  #371
Originally Posted by TAStevens
Yes they did! These are "every nut and bolt new" 572,s Dart Tall Deck, Edelbrock 355CNC Heads, 10.5 comp..etc... These are the first QFT anything I have ever had my hands on...impressive looking piece though...just whoever assembled these smoked a fatty after lunch one Friday I guess? My Baker Engineering Fuel pump is going back too...putting the other one on tonight. Pressure and volume are PERFECT! The bad oil leak...not so nice
Aside from the issues, your build seems interesting. I have not seen those edelbrock 355 CNC in action yet, but I know their price seemed pretty reasonable.
Is this a hyd or solid roller? Sounds like its on the way to making some good power
MILD THUNDER is offline
Old 06-12-2015 | 04:46 PM
  #372
First time using them..hyd roller....I selected these due to the 110cc chamber option....with a flat top JE piston...a true 10.5 comp ratio with GREAT flame travel....seems to be working??
TAStevens is offline
Old 06-12-2015 | 04:57 PM
  #373
so ta,you bought edelbrock cylinder heads and one head had a 2.250 valve in a 2.300 sized seat?and a quickfuel carb with no oriface in the power valve channel restrictor.i believe you but one has to wonder what are the odds of either one of these things happening.were both oriface,s equiped with a plug or just one.
mike tkach is offline
Old 06-12-2015 | 05:06 PM
  #374
BOTH were plugged! I should have took a pic! Well...they are still in my pocket!
Old 06-12-2015 | 06:03 PM
  #375
Cool. Looking forward to seeing the results with these heads. Which intake you running? Victor, sniper, dart, etc?
Old 06-12-2015 | 07:26 PM
  #376
Thanks...its just a FUN project! Learning a LOT! Next thing I want to learn about is Props...4 blade? 3 Blade?? Whose??? This is a heavy dog!
Old 06-12-2015 | 08:17 PM
  #377
What hull? What drives ?
Old 06-12-2015 | 08:26 PM
  #378
Formula 311SR1...new Konrad 540PRSs...Hueber 1300 trans...Konrads Optional lower
Old 06-12-2015 | 08:33 PM
  #379
That's why we don't "believe" what we receive...frickin got to inspect EVERYTHING!
Old 06-12-2015 | 09:52 PM
  #380
I sent my my brand new 850 Quick Fuel to a carb shop and they said it was bastardized with an 830 body and all mismatched on the inside.
Baja Rooster is offline
