More Speed
Old 01-08-2010 | 10:26 AM
The conservative drive height of the TRS is probably your biggest problem getting past 76 mph.
Kris Vogt
kvogt is offline
Old 01-08-2010 | 11:02 AM
GK's Avatar
GK
Take your HP upgrade cost estimates and add 30% for unknows and reliablity. Then compare that to the cost to trade up to a faster boat. The whole speed thing never stops until you run out of $. Be careful because you may never be happy.
GK is offline
Old 01-08-2010 | 11:06 AM
Panther's Avatar
Frank's Marine Service
Guys, check the start date on the thread. the subsequent posts are a joke.
Panther is offline
Old 01-08-2010 | 12:57 PM
fireboatpilot's Avatar
RIPSTA Racing Team
LOL, none of us even looked. All good info though for some other readers.
fireboatpilot is offline
Old 01-13-2010 | 07:54 AM
Panther's Avatar
buy a Fountain
Originally Posted by Panther
Well I did have your boat running about 90 mph back in the late 1990's so maybe you're onto something... But then I remember all the work it took....
Hey Tom, here's your boat 10 ys ago.
My old boat in the background, your boat in the foreground.
Your boat, notice twin towers in the background.
Panther is offline
Old 01-13-2010 | 11:03 AM
blue thunder's Avatar
I have an 86' Scarab Panther, with 502's about 550hp each. Merlin heads, Crane, etc. all the good stuff. Since I put the motors together I have had no running problems what so ever, and I hope to keep it that way (250hrs).
The question I have is where do you think I can benefit to get more top end. The boat is set up with TRS drives and currently on 25 Mirage Plus' which top out at 5000 rpms. I have messed around with different props such as 25 mirage, 25 mirage plus, 23Mirage plus and a crappy set of 22 4blades. Top speed on the boat has been a best of 76mph. The 25 mirage plus seem to be the best props for comfort, cruise and stability.
I installed nose cones, with no gain, actually lost 1-2 mph and about 100-200 rpm. I guess due to less slip? This year I also swithched the drives to have the props turn IN, instead of out. It seemed to cary the nose better and ride smoother with only a 1 mph gain.
The boat just doesn't seem to want to go any faster.
Any ideas?
You should rebuild the anti syphon valves in the fuel tank. It sounds like you are loosing fuel pressure at WOT and scrubbing speed. Are you trimming up at WOT? You should raise the drives a bit to get more speed. Also check your throttle linkaged, the carbs are probably not opening all the way. Have you gained weight? Ever think of cutting back on the beer? Weight will slow you down. If all that fails, sell the boat to someone that knows how to drive a performance boat and get a bayliner or apache.
blue thunder is offline
Old 01-13-2010 | 11:37 AM
Panther's Avatar
Well back then in 2002 the boat had 5/8" fuel pick-ups with "no" siphon valves... When I refabbed the boat in 99'/00' and had the new tank built I had them put in bigger pickups!
If anything I've gained 10-15 lbs yet the Apache is still faster!
I used to keep in touch with the current owner of my boat... I wonder how it's doing 10 yrs after I rehabbed it.. Probably due for another rehab.
Panther is offline
Old 01-13-2010 | 02:25 PM
offshoredrillin's Avatar
Attachment 405670
and just like now the hatches are up..sheesh Tom
offshoredrillin is offline
Old 01-13-2010 | 02:49 PM
Panther's Avatar
By the way... for the Panther owners, something to check out... There was a run of Panthers in the mid/late 80's that were pushed out of the shop very quickly... A lot of them have hooks in the transom because the resin was laid up so hot that it warped the hull in the mold. In addition, this short timespan, mid/late 80's they were not properly overlapping the laminate on the keel. To see if you have one of these models just take a close look at the keel from roughly under the helm area (windshield) foward to the bow. If you see any stress cracks on the keel it's likely you could have an issue.
The only reason I know about this is cause I found out the hard way.......when the bottom split open on the ocean and the cabin started filling up with water as I was coming in Pt. Pleasant Inlet....
When the glass shop fixed the 7' delaminated section (they cut a 7ft X 4ft section out of the keel) they told me they had done several jobs on the Panthers just like mine....
It was a very sad day for me but $7K in glass work later the boat was stronger than it ever was and while the boat was in the shop I (myself) blueprinted the bottom and gained a few MPH!
Can't make this stuff up fellas!
Attached Thumbnails More Speed-scarab-bottom3.jpg   More Speed-scarab-bottom4.jpg
Panther is offline
Old 01-13-2010 | 04:55 PM
Wow, that chit sucks panther. I think mine would have come apart long ago if I had this problem. Although I do have a lot of hook I believe to be from the hot layup issue you mention. We'll fix that though and hopefully breach the century mark
