rocker arm stud diflection >
Old 04-19-2015 | 08:02 PM
  #61
Originally Posted by Black Baja
Obviously you have no reading comprehension. Please read and re-read post #20 and maybe you will get it on your own. I may have some bullchit coming out of my mouth but obviously you have diarrhea of the brain.
i was right about you,you spew bullchit and think you are fooling people,my brain works fine.you can lie but everyone sees past your bs thanks to this thread.i am glad that you admit that bullchit comes out of your mouth but here is a newsflash,everybody knows that!carry on spreading bad information as that is all you are good for.i guess you have diarrhea of the mouth,lol.
mike tkach is offline
Old 04-19-2015 | 08:12 PM
  #62
Tinkerer's Avatar
Mild Thunder - They are the proper AFS parts for those heads. These engines probably have 200 + hours of operation WITHOUT even a hiccup. That's at 5400 to 6000 RPM depending on the boat.
Tinkerer is offline
Old 04-19-2015 | 08:24 PM
  #63
It's not bad information if you didn't have so much diarrhea between you ears you could probably look at a Pro 1 head and say (yeah I could see the potential for a failure). But I don't see that happening. i have to ask Mike why do you always do this? Does it give you some sense of superiority or something? What's the deal. Take pleasure in running people off? What's the deal really?
Black Baja is offline
Old 04-19-2015 | 08:27 PM
  #64
Not sure what afs is .
I was asking, because I've seen where guys run a standard bbc rocker stud, say from a GM head, and transfer it to an aftermarket head. Not only are the threaded base portions shorter, the effective stud length, is shorter as well. So, when you have longer intake valves with an aftermarket head, you may find the set screw is sunk way down in the lock, and there is minimal thread engagement on the stud as well. I didnt say you had incorrect parts, was just asking what you had there.
MILD THUNDER is offline
  #65
Are those pro 1 heads?
Are you sure there isn't an issue with the rocker bosses. Those heads are notorious for that.
ok bb,lets see you bullchit your way around this!
Old 04-19-2015 | 08:34 PM
  #66
Mtk
I like you , if you're right, be humble, if not .. well its not a competition. Many of of us don't know the people offering advice.
Bb , you obviously know a lot as well, and post a bunch of excellent information, but everything including this post is no more than than the posters experience or opinion, but thats why we are all here, to get facts and opinions.
buck35 is offline
Old 04-19-2015 | 08:39 PM
  #67
And now you cometely lost me on this one. I have no clue what you are getting at.
Old 04-19-2015 | 08:43 PM
  #68
basicly i get tired of people like you posting bad information.someone might believe your trash and not buy a head that has worked well for a ton of people,including myself,just because you screwed up a set that does not make them bad.i think i will foreward this thread to richard maskin,im sure he would get a laugh from your misinformed posts.
Old 04-19-2015 | 08:49 PM
  #69
so now your story IS that the bosses on pro1 heads are a problem,man you sure change your story a lot,do you even realize how you flip flop.if you would like i can quote you,r posts just as a reminder of the trash you spew.
Old 04-19-2015 | 08:57 PM
  #70
The head has issues. It's not a myth. When you use a rocker arm the geometry is always wrong that's why there is a pattern/ sweep. What's your point? You walk on water. Have a magic wand you can wave over a valve train and it becomes perfect. Not sure what you are getting at. I on the other hand was simply trying to give the OP I different idea than what was posted by others as what to look for.
The Dart pro 1 head was designed to be a light weight head. They come in around 29lbs each. There race series come in around 45lbs each. Where did all the weight go. Maybe someone used there magical wand combined with a sprinkle of pixie dust. I don't think advising the OP to take a look at the stud bosses is bad advice. If you feel as though it's not a good idea to pay attention to this area of a cylinder head then don't pay attention to it. I've seen problems with intake and exhaust bosses with these heads. Was it a geometry issue? There is always a geometry issue its the nature of the beast and BBC's have the worst of them all. I've even seen a few sets of Pro 1's where alot of extra effort was put into the stud bosses to try and combat issues before they happen.
What I meant by the geometry problem was a generalized statement not directed towards a pro 1 head. But a BBC in general.
ok bb,i think we have you figured out.make sure you come back with something you think is witty,lol.
