BBC Engine missing side caps? >
Old 05-08-2015 | 11:25 PM
SB
Be careful, I'll cap your azz, or block.
SB is offline
Old 05-09-2015 | 12:00 AM
BUP
100 % Agree about improper winterization or not done at all. The other possibility is very bad corroded area the brass freeze plugs rest in. But that one will be a long shot here. I would check your exhaust manifolds out very carefully as well - water circ pump and oil cooler to
BUP is offline
Old 05-09-2015 | 05:25 AM
MER Performance's Avatar
I'm not qualified to post a comment on this subject,,,,,,,,,,
MER Performance is offline
Old 05-09-2015 | 05:56 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Don't need no stinkin' freeze plugs. They just hold in hot water.
US1 Fountain is offline
Old 05-09-2015 | 09:42 AM
Alright, if it is a freeze (core) plug "popped out" and you have no clue what it is all I can say is ....run Forrest ....runnnnnnnn
f_inscreenname is offline
Old 05-10-2015 | 11:02 PM
Randy Nielsen's Avatar
When that happened to my Eliminator the valley was cracked in 8 places from the deck to the lifter galleys. Good luck.
Randy Nielsen is offline
Old 05-10-2015 | 11:13 PM
Come on , Ratman , we caught you this time. Right ?????
PARASAIL941 is offline
Old 05-11-2015 | 12:40 AM
Has anyone popped a freeze plug and not have a cracked block? Doesn't sound like the system works very well.
Baja Rooster is offline
Old 05-11-2015 | 12:47 AM
Rookie's Avatar
Yes, my 351 Windsor in my Sea Ray 240 SRV popped the freeze plugs one winter. I couldn't pound in new ones so I just bought the rubber ones and ran it for 3 more years prior to selling it.
Rookie is offline
Old 05-11-2015 | 01:16 AM
BUP
^^^^^ agree about the Fords - NO BS I have seen in person thru out many years about 60 Fords - 5.0 and the 5.8 that had popped some freeze plugs and all lived. The Ford casting are thicker than GM.
Fords seem to pop the FP's way before the block cracking.
The GM 4.3 L is the worst, it will crack in the lifter valley area and for 1996 & up year models, if you do not pull the intake manifold drain plug out to drain - it will crack on the bottom side of the intake manifold..
BUP is offline
