Recommended fuel line sizes to support NA 575 HP
OK everyone, I need some educating. I understand how important it is to not run an engine lean due to an undersized fuel systems. But I have never changed my pickups,or up-sized hoses. I have gone from the Mercury sea/fuel pumps to electric Mallory 140GPH fuel pumps. Every winter I drain my tanks. I just unhook my fuel line from my fuel pressure regulator at my carb and turn on my fuel pump. I have timed it out and I can fill up a 5 gallon gas can in under 3 mins. That is almost 100 GPH actual gas the hose and my pickup can supply at free flow. I do understand free flow rates and that flow and pressure are inverse proportion and how to choose a fuel pump. But when it gets down to it by math, flow charts and actually filling gas cans, why can't a 3/8" hose support more than 500HP? I also understand that pickups and fuel lines are changed for electric pumps because it is important not to cavitate the pump and hurt it.
Wait till your stainless fuel line finds + battery terminal or a stray +12v wire that that got knocked loose in 3'-4's and is now glowing red hot in your bilge. I'm going to be changing out to rubber USCG rubber hose this year.
It hurt bad ! Thank god I didn't blow up.
Engine ground was bad, so I became a tad better ground.
Yikes !
I also thought about using something like the push-lok hoses and fittings. Those are non-conducting, aren't they?
I also am not recommending any hose size just trying to understand.
SB Not trying to argue or disagree. I know that some times conversational tone and inflection can not always be conveyed through written text. It's all good
I'm confused. So are you saying to go with with rubber hose all the way up the the regulator or the carb? I was under the impression that rubber lines were not allowed between the pump and the carb by USCG regulations. All the factory Merc motors that I have seen had hard metal lines going up to the carb. Wouldn't these conduct just like the braided SS lines?
