Carburetor to EFI conversions
Does anyone have any experience with swapping out carbs to one of those bolt on replacements (i.e. MSD atomic, FAST EZ, Holley, Edelbrock, etc)? I've got a '83 Scarab with a pair of mildly built 454's putting out around 450 hp each...i just feel like they would run a lot better on efi along with the MSD ignition over the old Thunderbolt IV stuff. I have custom marine headers and was curious if the water in the exhaust would mess with the O2 sensors. I've sent emails to a couple of the companies listed above without response...any advice would be appreciated.
Tons of information in this thread. http://www.offshoreonly.com/forums/g...-everyone.html
Only a little over 400 posts to read :D To answer one of your questions, the O2 sensor needs to be mounted so it is not exposed to any water. Most guys are running dry to the tip exhaust or the water enters the exhaust right before it exits the pipe. I am making the switch from carb to EFI this fall, looking forward to smooth idles and stable RPM when shifting in and out of gear! |
Originally Posted by Space Toast
(Post 4307893)
If your going to do it yourself contact Haxby on here, he has good prices plus can help you navigate thru all the set up.
| All times are GMT -5. The time now is 02:38 PM. |
