How do I set timing with no marks on crank?
Get 5 adjustable timing lights and time a motor. Move the timing all over the place. What you will find with an adjustable light the more you advance you give the light the more it will be off. I have a bunch of timing lights over $600 in one. The best one I have is an old beat up craftsman that looks like it's from the 60's. I'll use an adjustable light on stock motors but thats about it. If you played around with motors that completely melt down with 1-2 degrees more timing faster than you can blink your eyes you might understand. But if your just happy running around trying to look cool with a pair of motors that smoke like freight trains and putting shinny puke tanks on to compensate for improper honing/ ring selection you will never understand.
Also what do puke tanks have to do with timing?
Puke tanks have nothing to do with timing lights. Just trying to help Dan understand that he will probably not understand. Yes the adjustable lights are inaccurate. Sorry if I'm not clear I'm exhausted. With a stock motor you don't have the compression you do with a max effort NA or blown motor. With the lower compression stuff if you set the timing at 30 and it's actually 33 it's highly unlikely it's going to melt down. I've spent lots and lots of time around nitrous motors. My experiences working on these types of motor has made me extremely paranoid when it comes down to ignition timing. Some of them have 0 degrees of timing when the juice comes on. 1 degree of timing in something like that can be $100,000 mistake. Knowing your timing light , true TDC are extremely important. I one adjustable light that will give you a different number every time you use it up to 8 degree difference without ever touching the distributor.
[QUOTE=Black Baja;4310078]Puke tanks have nothing to do with timing lights. Just trying to help Dan understand that he will probably not understand. Yes the adjustable lights are inaccurate. Sorry if I'm not clear I'm exhausted. With a stock motor you don't have the compression you do with a max effort NA or blown motor. With the lower compression stuff if you set the timing at 30 and it's actually 33 it's highly unlikely it's going to melt down. I've spent lots and lots of time around nitrous motors. My experiences working on these types of motor has made me extremely paranoid when it comes down to ignition timing. Some of them have 0 degrees of timing when the juice comes on. 1 degree of timing in something like that can be $100,000 mistake. Knowing your timing light , true TDC are extremely important. I one adjustable light that will give you a different number every time you use it up to 8 degree difference without ever touching the distributor.[/QUOTE
Oh well then I must be a lucky guy, cause I have run blown NOS engines in my boat in the past timed them with an adjustable light and have not detonated them, I used the same light on my 12.5:1 NA Camaro engine, my 427 corvette engine, my nasty little 302 cougar engine, without a hitch must have bought a more accurate one than most!
It stopped a lot of our Nitrous melt downs. I thus then left the Snap On Digital at the shop (reg car repairs).
Word has it that it was because of the bulb, not just the electronics ? So said some big timing light test many moons ago. Dunno:
Okay, same subject.
Good conversation.
Who makes sure their pointer points at true 0 ?
That said, timing tape can be put on such the pointer doesn't have to be moved or replaced with an adjustable one.
But, if you use a balancer with marks already etc'd in it - then an adjustable pointer is usually a must.
Good conversation.
Okay, same subject.
Good conversation.
Good conversation.
[QUOTE=abones;4310084]
Have you ever tried playing the lottery? If not you should give it a go.
-5568.jpg)
