Another fuel system setup question - fuel / water filter before or after mech pump? >
Old 06-02-2015 | 11:01 PM
14 apache's Avatar
Originally Posted by MILD THUNDER
Yes, most had the spin on filter, plus a filter before the injector rail if I recall right.
Thought so but didn't want to be stupid.... LOL
14 apache is offline
Old 06-02-2015 | 11:04 PM
Heres a 525EFI filter thats pre injector rail. Then it also has a typical style water separator deal too.
Attached Thumbnails Another fuel system setup question - fuel / water filter before or after mech pump?-%24_57.jpg
MILD THUNDER is offline
Old 06-02-2015 | 11:11 PM
14 apache's Avatar
Looks like same filter on my engines if you can post part number.
Old 06-02-2015 | 11:12 PM
Its on the box in the pic lol
Old 06-02-2015 | 11:14 PM
14 apache's Avatar
Couldn't read it till I clicked on it. to funny
Old 06-02-2015 | 11:16 PM
Hahaa, that is funny chit. I thought you maybe were like Mike Tkach and needed to put on your spectacles to see whats going on here.
Old 06-03-2015 | 06:16 AM
Originally Posted by Black Baja
Boat rolled over 95mph last trip out last year. He and 1 other ejected boat landed upright. No lanyard kept running. Somehow cam back to an idle wheel turn all the way one direction boat spinning in a circle. Late in the day middle of the Bay no boats on the water. One made it back in and shut it down. Yeah, some people can do it all wrong and get away with it. Some can't.
That sum***** needs to go out and buy a lottery ticket. Yep, some folks seem to live a charmed life like that, while others get zapped in the azz by lightning no matter how careful they are.
Budman II is offline
Old 06-03-2015 | 06:27 AM
Those rock filters are a good idea in all carbs imo. Was rebuilding a pair of demons for a buddy this week, and found this in his needle/seat.
Are we supposed to run a filter in front of an electric fuel pump as well? I was running an inline filter in front of mine, and I think this may have contributed to my problem.
Mild, I replied to one of your posts on another thread talking about filter heads for fuel/water separators. You posted a link to Fleet Filters for a filter head, along with a link to a fuel/water separator (PN 33405). I don't have room on my setup for a filter that long, so I'm trying to find a shorter filter that will work with that unit. Found PN 33244, similar specs. Will that one work? Can't remember if it was labeled as a fuel/water separator, but I think the water just settles to the bottom anyway. Let me know if that one will work.
Old 06-03-2015 | 07:38 AM
I personally wouldn't run the fuel filter/water seperator before the pump. If you want a filter before the pump then run an additional filter that doesn't filter to as low of a micron level so it doesn't restrict flow as much, but I dont believe this is really necessary with the stock mechanical pump. Filter before the pump is going to restrict flow to the pump, filter after gives some slight pressure downstream of the filter. Better to have a little positive pressure at the pump then to restrict that flow to it.
ealesh33 is offline
Old 06-03-2015 | 08:30 AM
I agree that the mechanical pump probably doesn't need one, but I thought the electric ones were a lot more sensitive to crud going through them. That's basically what my question was about, in the unlikely scenario where I go back to electric.
Edit: Oops - Now I see that you were replying to my original question, not my more recent one.
