well  do i have the start of a trans prob >
Old 06-03-2015 | 10:11 PM
ROB FREEMAN's Avatar
Default well do i have the start of a trans prob
did some preventative maintenance on the boat .. changed impellers .. thought id backflush the engines and clean them .. decided id check and make sure all was well .. n noticed starboard engine prop spins pretty fast in neutral while the other spins hardly at all .. mel riggs repuilt these and upgraded them for me .. also noticed same one turns a little harder sitting there dormant .. any help ar clues will be appreciated .thanks rob ... paging mild thunder ...lol
ROB FREEMAN is offline
Old 06-04-2015 | 12:05 AM
Sounds like the clutch pack is a little tighter in the one that's spinning. You talking about out of the water? Probably won't be an issue when in the water. Did he just rebuild these?
picklenjim is offline
Old 06-04-2015 | 06:56 AM
Typically that would be a sign of warped clutch/clutches. . Is it spinning like really fast, or just a slow turn? I wouldnt be too concerned if its just a little slow turn. But, if its spinning enough to actually move the boat when in the water, i'd say you prob have a issue with clutches or maybe a sealing ring issue. I'd make sure the trans shift cable is properly adjusted as well. One of the things I always do in my boat out of habit, especially before I get on plane, is double check my shifters and give them a firm push against the stops to make sure they are fully engaged in forward. They don't like not being fully engaged.
I know you have some healthy engines in the boat now making a good amount of power. I don't know how far Mel gets into upgrading them, but I think you are probably at the point where a simple addition of an extra clutch may not be enough. Stepping up to a Bam cyborg might not be bad idea. A good way to get warped clutches if everything is setup right, is simply overpowering them, slippage=heat, heat = warped clutches.
MILD THUNDER is offline
Old 06-04-2015 | 08:16 AM
bcfountain's Avatar
Registered User
I had the same issue last year on my 10meter.the clutches were waraped/overheated.it did the same thing as yours.i rebuilt both trans this winter.took care of problem.
bcfountain is offline
Old 06-04-2015 | 11:30 AM
Seems fast. But does not do anything that I notice in the water. Definitely not moving the boat or anything of that sort.
