Speedo hook up? >
Speedo hook up?
Speedo hook up?
Old 06-08-2015 | 06:04 AM
m50
Default Speedo hook up?
Hi, I have just gotten a 95 Fountain 32ft with bravos. Where do the speedo tubes hook up to the drive? There are both tubes coming thru transom but neither one is hooked to anything. I realize that they will not be accurate but would like for the speedo to at least work. Thanks
m50 is offline
Old 06-08-2015 | 01:13 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Raise the drives fully up and feel for the plastic fitting between the two Rams inside the center front of drive. More of a feel thing than see thing. Gotta twist the lever to the side and lift out.
US1 Fountain is offline
Old 06-08-2015 | 01:24 PM
Knot 4 Me's Avatar
Are just the black rubber hoses visible or do they have the yellow fittings on the end of them? The yellow plastic barbed fittings I reference is part number 16 in this pic:
https://www.mercruiserparts.com/Show...sp?dnbr=809808 96&ivar=images/COMMON/18720.png&inbr=1943&bnbr=180&bdesc=BELL+HOUSING
As US1 says, raise the drives all the way up and look at the top of the forward section of the lower unit. You will see a hole with two slots where those fittings push into and then turn to lock in place.
Knot 4 Me is offline
Old 06-09-2015 | 05:32 AM
m50
Yes all that is there is the black hoses. I will raise them up and see if I can figure it out. Thanks
I could not get the link to work. Knot 4 Me
m50 is offline
