Hesitation / Bog under acceleration >
Old 06-16-2015 | 10:30 PM
Originally Posted by cdaniel525
Damn... might be my issue MILD THUNDER. I had adjusted the 4 corner idle screws after going for that first ride... I turned them in a 1/4 turn each BC it seemed to he running a lil rich... that said after I ran into this hesitation I turned them 1/4 back out... maybe I'll try going out some more
You can take the screws out and throw them in the lake/river or whatever it's not going to make it backfire. When it backfire it's because you have ignition when an intake(s) valve is open.
Black Baja is offline
Old 06-16-2015 | 10:37 PM
a lean condition can cause a backfire.my money is on poor carb adjustment.the engine can also backfire from not enough timing at low rpm.
mike tkach is offline
Old 06-16-2015 | 10:41 PM
Some guys skipped the high school automotive class and went straight to the spintron.
A lean condition CAN CAUSE A BACKFIRE thru the carb.
MILD THUNDER is offline
Old 06-16-2015 | 10:43 PM
Yeah excessively lean condition. 2500-3000 rpm just coming off idle circuit? Yeah ok.
joe,doe you know what PPIOFAC stands for?
Old 06-16-2015 | 10:45 PM
Yea, in NUETRAL I don't know about the engines you build, but I can rev my engines in nuetral, to 2500 RPM with very little throttle blade opening.
Old 06-16-2015 | 10:46 PM
cdanial525,post a pic of the plugs.
Have fun with it guys. Wait a minute why don't you tell him to go and buy a wideband and a Quickfuel carb. And he will be good to go...
Old 06-16-2015 | 10:47 PM
Why dont you tell him how to melt your pistons several times and lose control of your overpowered 20ft boats and crash them into the rocks, barrel roll them, and then tell everyone about your nascar, world of outlaw , plug reading expertise.
Old 06-16-2015 | 10:51 PM
Joe, please more research get that facts straight please!
