Water pressure; Looking for the real answer! >
Old 07-16-2003 | 12:28 AM
  #41
i bought 2 of wette vette's pressure relieve valves back in march, the kits comes complete with valves, watter jacket "T's" and all brass fittings. i bought them thinking i would need them, but my engine builder decided to do something different with my system. i would like to see these things working, i've talked to people who have them, everyone i've spoke with likes them but i haven't had the opportunity to actually see them in operation. they are brand new, never used, still in the box, i think i paid $120 or $130 for each kit, if someone wants them i'd let them go for $90 or so.
dean campbell
email = [email protected]
cell = 801-201-5856
dean campbell is offline
Old 07-16-2003 | 04:46 AM
  #42
Kanookstr's Avatar
32' SUNSATION
Thanks US1, that worked
Kanookstr is offline
Old 07-18-2003 | 08:37 AM
  #43
I have a pair of 496HO's in a 353 Formula, and recently had a similar problem, with the water pressure rising to 20 lbs at idle W/ water temp running 170-180 and the starboard exhaust running hot. we found the steering cooler was partially clogged with debris restricting the water-flow.
We fixed this by removing the intake hose on the main heat exchanger, and clamping a water hose to it then remove the blue drain plugs from the seawater pump, then back flush with the water hose. We filled the bilge with a bunch of debris. After that every thing was normal. 3-5 lbs @ idle and 25-30 @ WOT.
If you have had allot of rain and junk in the water where you are, like we have had, you may want to check this. I have now done this 3 times in the last couple weeks. Time to add strainers!
Island Hopper is offline
Old 05-16-2004 | 06:20 PM
  #44
Dave1972's Avatar
Default Re: Water pressure; Looking for the real answer!
Can someone put me in touch with Wette Vette (Craig)? I need to renew my membership (no access to PM's) but I need to get in touch with him pronto about the kit he has for water pressure. A number or email address? My email is: [email protected].
Thanks,
Dave
Dave1972 is offline
Old 05-17-2004 | 12:24 AM
  #45
sleek willy's Avatar
Mercury racing- part #863208A3 valve kit-relief list each $120.48 BAM Marine $102.72 mercruiserparts.com [email protected] . I'm finishing up my installation now, after rebuilding the motor due to leaking headers and head gasket. -Sleek Willy
sleek willy is offline
Old 05-17-2004 | 07:57 AM
  #46
Dave1972's Avatar
Thanks Sleek....I've got the merc numbers but am trying to get in touch with Wette Vette as he has made his own pressure relief valve and it's adjustable where the MERC part is not.....how difficult is the install with the MERC stuff? Where did you plumb the relief hose?
Dave1972 is offline
Old 05-17-2004 | 03:34 PM
  #47
Dave1972's Avatar
TTT....anyone have Wette Vette's contact info?
Dave1972 is offline
Old 05-17-2004 | 04:31 PM
  #48
Kanookstr's Avatar
32' SUNSATION
Dave, go to this link, and at the bottom is the Adjustible version you are looking for.
Adjustible pressure relief
Old 05-18-2004 | 10:38 AM
  #49
Dave1972's Avatar
If I wanted to tap into the existing bilge pump hose could I plumb the pressure relief valve to it? I was thinking that I could put a T in the bilge hose and put a check valve on the bilge side and another check valve on the relief valve side and use the same thru-hull dump? I have found the check valves in the McMaster-Carr catalog and they are inexpensive. Would you recommend increasing the size of the hose from 3/4" to perhaps 1" or wouldn't it matter? I just want to make sure that I can get rid of all the water without having flow problems. Any other suggestions?
Dave1972 is offline
Old 05-18-2004 | 10:40 AM
  #50
Dave1972's Avatar
Perhaps welding a 3/4" bung to the exhaust would be easier or better?
Dave1972 is offline
