Help with Flywheel or Ring Gear decision >
Old 06-24-2015 | 07:57 PM
Originally Posted by Importrepairguy
You make it sound easy. lol. My concern was the outdrive related stuff & the shifter cable adjustment. Should engine alignment be an issue if I remove the bolts from the Hull and leave the adjusters intact, attached to the Motormounts? Wanted to know if that was a concern.
That's exactly how I do it when they have adjustable mounts. That's a two hour job. If you quit playing around on the computer u could go knock it out take it out for a sea trail and still be in bed at a decent time. Depending on how the sea trail goes.
Black Baja is offline
Old 06-24-2015 | 10:01 PM
Lol, you have jokes.... I don't have all the parts on hand yet. Still trying to figure out how I'm going to pull engine. I don't have an Auto lift available,at this time, first choice, and an Engine Cherry Picker is not tall enough, unless of course I somehow bolt it in the bed of my truck. My truck happens to be on 40" Tires and 10" Lift, not a pleasant option drilling holes in my bed either. The tree branch suggestion has come up, Red neck engineering at its finest, Mother nature can build some tough trees, however, my yard consists of Bushes and Palm Trees, The type trees with no branches. I'm new to the area, so haven't networked with anyone that may have a fork lift on hand. Id like to have the boat in the water for the 4th, so I'm motivated, just getting all things in order and devising a plan.
Thanks for the comical relief.
Importrepairguy is offline
Old 06-24-2015 | 10:04 PM
SB
Pulleys, an ATV, and some beers !
Edit in: Ooops. got you mixed up with the gimabl bearing guy (DNA) for a second.
SB is online now
Old 06-24-2015 | 10:18 PM
Many years ago my brother and his buddy pulled a 440 Dodge motor by building an A-frame out of 4x4's, and used a chain hoist. I have read on here that someone did the same thing with a boat. Triangulation is your friend.
Budman II is offline
Old 06-24-2015 | 10:21 PM
The Gimbal bearing, good point. i bought the Bellows Service kit, comes with a new one (gimbal), should I buy the tool, or is it simple to replace (The exerpt above, makes it sound like a daunting task)? Machine shop is an option as well, however they are terrably slow in my neck of the woods, Theyve had my LSX Block for 3 months...; /. I was going to inspect the U-joints anyway on the driveshaft, and repair if necessary. And as always, my fridge is full of beer.
Old 06-24-2015 | 10:31 PM
Harbor freight sells a Gantry Crane for like $750.00, And then add the chain hoist to it, another $50-75. It measures about 9ft across and can go up to 8' I think. Ive looked at it, however, Its a one time use, WTF am I gonna do with a $900 Contraption after this job? make a swing outta it I suppose. But its a hefty investment, for a non paying job. lol
Pic and Specs attached for your amusement.
Description
This 1 ton capacity gantry crane lets you hoist heavy items easily! The all steel gantry crane adjusts from 100 in. to 147-1/2 in. high to provide a sturdy overhead lift point to lift car engines, heavy machinery or equipment. An easy crank handle allows for easy lifting and lowering while ball bearing casters let you move the lifted object hassle-free. This gantry crane is for use with a trolley hoist (sold separately).
Adjustable I-beam with nine positive stops
Easy crank handle raising and lowering
93-11/16 in. distance between posts
5 in. ball bearing casters, two locking casters
All steel construction
Attached Thumbnails Help with Flywheel or Ring Gear decision-harborfreight-gantry-crane.jpg
Old 06-25-2015 | 08:35 AM
Knew a guy one time that grabbed a chainfall towed his boat with unbolted motor on trailer out under a low backroads bridge slung a long tow chain around a support from underneath ,lifted it out ,pulled out then backed his truck and boat under the hanging motor in a "v" position lowered motor in bed of pickup grabbed his chain and chainfall and down the road he went .
wouldnt use a branch , fully dressed bbc is heavy
airjunky is offline
Old 06-25-2015 | 08:55 AM
I substantially reinforced a ceiling rafter in my pole barn and put a chain hoist on it. I will tell you this much - with a half ton of BBC hanging in the air, I am hesitant to trust my life and fiberglass to a chain made overseas of unknown metalurgy. At least go for the biggest, highest capacity chain that you can afford. Some of the stuff that looks substantial in the hardware store can let you down in a big way. Had to replace motor mounts in a Dodge Dakota one time. Used a chain that I had laying around with my cherry picker to lift the motor up off the mounts. I had just pulled the old mounts out of there and BAM! - that chain busted. A second earlier and my hand would have been pinned in there. I always catch my breath a little when that motor is hanging up there in space 10 feet off the concrete floor.
For half that purchase price you should be able to find someone who would pluck it out and set it back in with a forklift or something. Of course, I guess you might be able to sell it on CL after you are done and get some of your money back. Or hang onto it - you will find out if you hang around OSO for a while that boat engines have a habit of going in and out of a boat numerous times.
Old 06-25-2015 | 09:54 AM
Looking to rent a Gantry Hoist from Sunbelt rentals. $250 per day. Or Pick up Friday and Drop on Monday for 1 day price. Sounds like a winner. I'm rounding up all other parts I need to knock engine out.
Old 06-25-2015 | 10:06 AM
Put in a new starter also & make sure its nice and tight !!!!!
575cat is offline
