Help with Flywheel or Ring Gear decision
Knew a guy one time that grabbed a chainfall towed his boat with unbolted motor on trailer out under a low backroads bridge slung a long tow chain around a support from underneath ,lifted it out ,pulled out then backed his truck and boat under the hanging motor in a "v" position lowered motor in bed of pickup grabbed his chain and chainfall and down the road he went .
wouldnt use a branch , fully dressed bbc is heavy
What's is wrong with flipping a ring gear over? I've done it more times than I can count. With no issues. So could you please explain. Most of the time you end up with the teeth missing in one spot. Why? Because when you shut the motor off this is where it stops and has to restart in the same spot over and over again.
Just curious, what do you do for a living ?
