Wideband location ...
Happy 4th weekend folks.
Getting back into the boat after a little break. I have stainless marine manifolds for my gen 6 502.
I have mounted the sensors upright and towards end of risers. (Cut a large hole welded bung to bottom of riser and then patched water jacket. So it's sealed) how ever I'm running into reversion getting water on sensor at low speeds and idle and sensors don't last long.
If you have mounted one, where at?
Post up photos for refrence
Don't have a pic, but its in a header primary about 8" from the flange (against the head) in a set of lightning headers.
Had a bung in the collector and the sensor would get wet and die running it hard, it was fine at idle/cruise.
Jeff I have the same heat sinks to try to make it harder for water to get to the sensor. My sensors are 3 " after the turbo's but my exhaust is straight out the back with the water dumping over the end of the pipe, ( I have dry exhaust). The distance between the sensors and the water outlet on the outside is about 28" I wasted a sensor 2 years ago, but Im not sure if it was from the engines running pig rich or water, All I know is it would not recalibrate. How far are you sensors to the point where water is mixed in with the exhaust?
