Does this motor look rebuilt
#91
they were done 5 months ago and ran after that. thats y he did not want me to take it apart to see what happen to it.so if his intake leaked that he took off and it looks like he used the same gasket thats what took out the motor he got 4hrs out of it and it took him two weeks to take it apart i seen motors rust up in one day
Either way, I was there when the motor came apart, I've also seen all the texts you sent dale when you were pedaling this crap. You are a LIAR.
Dale doesn't know much about mechanicals, that's why he trusted you. I even warned him about your bad rep, but he trusted a friend that vouched for you. Anyone with half a brain can tell you didn't do jack to these engines. And just because they came out of a year 2000, doesn't mean the are. Given the all the high quality primo stuff you carry, I doubt you've ever seen a boat with the original power in it.
The motors did have great oil pressure before the bearings spun. The junk carb's dale used were set up by Nickerson Performance, and the timing was set by a professional (after you scammed him our of his ignition system- class act you are)
Like I said before, crawl back under your rock, or soggy old apache, or whatever you live under and go away.
#92
#94
#95
#96
the motors in question came out of a yr 2000 41 avanti, not sure where this 1994 garbage comes from, not to mention the motors were factory sealed. never once did i say the motors had a complete rebuild. i told dale exactly what was done to the motors. the motors had complete head jobs with new valve springs from chris at cnc machine. all new rings and a fresh hone on the cylinders .
I'm not expert but it doesn't add up. They were factory sealed and not rebuilt. But new head job and rings with honed cylinders. The moment you take an intake, head, or oil pan off the factory sealed idea goes out the window along with whatever gaskets the factory used from 94. I'm just a blue collar young man and I see this guy is pulling ideas from anywhere to try and sound like he didn't lie
#97
#98
#100
The cafe deal is suffering because of it he says but I won't give more details on that, I will let him if he chooses to, I asked him about his situation when dale got screwed...
