Does this motor look rebuilt
#151
Detonation most certainly will eat the bearings out. That's usually the first thing too go. If it's bad enough it will push the crank completely out. I've done it!! Had too have new main caps and align bored. 5 and 7 cylinders fired together and oil pressure went from 80 to 5 in a split second at 5500. If I'm wrong someone correct me but detonation usually will eat a bearing before piston from my experience or luck..
#153
true, but in this case that wasn't it.... plain and simple.... and in my 25 years I seen the bearings fine with melted pistons....I never said it CAN'T happen....I don't see it here though..
#154
Really don't matter full force the moral of this thread is someone got took. I've been watching it and haven't responded on this site for awhile but the problem here is someone got ffked and that the seller should at least try too make it right. I don't know any of them but I feel for this dale guy. Summers almost over and through a few long nights in the bilge and blood sweat and tears thinking he is gonna have a better setup etc and nope he's just fked. Bad deal....
#155
Exactly....
really don't matter full force the moral of this thread is someone got took. I've been watching it and haven't responded on this site for awhile but the problem here is someone got ffked and that the seller should at least try too make it right. I don't know any of them but i feel for this dale guy. Summers almost over and through a few long nights in the bilge and blood sweat and tears thinking he is gonna have a better setup etc and nope he's just fked. Bad deal....
#157
Oh I am sorry, show me the post where Dale pulled rods and pistons to fix something, added rust and put it back together.... Apparently Paul is your buddy, that's fine, but he still did not sell Dale 2 fresh engines as claimed... PERIOD, I don't care WTF Dale did those engines were not FRESH....
endeavor1 - TENSION if you two are examples of the brain trust that advised bigboat28(Dale) in this deal no wonder things went south.
Can you read and comprehend anything? Direct your vitriol to the parties responsible for it. Where is the "friend" of Dale's that helped
broker this deal?
Full Force - there was more than Dale peeking under the intake now wasn't there? I used the word "altered" but maybe "modified" or
"changed" is better suited here. RT930turbo says different carbs and tune(timing?) was done by a "professional". Why isn't he part of
the conversation? Let's ask another professional engine builder about honoring a warranty shall we?
Mike Tkach or sutphen 30 if bigboat28 bought an engine from you and he pulled the intake, replaced some parts including carbs and
had a different "professional" re-tune, set timing, etc. would you be O.K. with that? Would you honor your warranty if this motor broke down?
No I don't have all the answers but then again I don't buy my boat parts from a junkyard.
As tommymonza so eloquently wrote, "Who the Hell would be Dumb enough to trade 2 of their running freshwater 420s and 7500 bucks
for 2 motors of unknown origin?
bigboat28(Dale) got taken. You "friends" should have looked out for him.
broker this deal?
#158
If there was ZERO rust and not wasted looking cam in that engine, I would be more open to hear Pauls side, but pics don't lie.... I am making my opinions off pics I seeI did not see the engines before and I have not now, but I can tell you they are not "fresh" everything else does not matter to me.... so if you buy freshe ngines they live but find out they are not actually fresh, is that ok since they run ok? no it is not....
At best Paul says heads were completely new and redone, the pic CLEARLY shows otherwise, look at the head surface, and gasket, with a couple hours the gasket should look not even used and no rust like that... come on....
[ATTACH=CONFIG]543814[/ATTACH]
#159
broker this deal?
broker this deal?
#160
[QUOTE=dbkski;4337554
"changed" is better suited here..[/QUOTE]
what part of they took intake off after the engine failed,,and all the rust is what they found.I'd have chit when the distributor came out full of chit on it.
as for the question to me,,I've sold a few motors w/ no intake on it.but lets not digress from the rusty piles of chit your buddy sold.
