Long row back
It took 2 hours to idle to Huron, OH from Kelly's Island. Instead of a broken rocker, we could have really hurt the engine if the rocker would have broken at full song vs. just starting to get on plane. The lifter and cam will be bore scoped this week and with any luck we won't have any additional damage. We have a spare Jessel exhaust rocker so if all goes well we should make the LEOPA Fall Poker Run. It is likely time to change out these rockers and freshen these engines as we have about 80 hours....lot's of time 6000-6500 RPM.
[ATTACH=CONFIG]543543[/ATTACH]
The cam is a 55mm and I think the duration is 262/268. Pretty good lift but would have look it up. The exhaust wall push rods are .165 wall, would have check the intake PR specs. We have about 500 ci with 4.60 bore and 3.80 stroke....very similar geometry to the SBC and the APBA Super Cat engines.
How many hours did you have on your Jessel rockers when they broke? Did you break multiple rockers at the same time?
