Power Steering Pulley >
Old 08-04-2015 | 09:41 AM
eightsecmopar's Avatar
Default Power Steering Pulley
I want to replace my power steering pulley with a Billet one, is it necessary to use the mandrel or can you just use the billet press on pulley? I thought I read somewhere that the press on ones will walk themselves off.
eightsecmopar is offline
Old 08-04-2015 | 03:17 PM
you need to use the correct puller to remove and correct threaded installer to install, if just try a press, can't see that working without destroying something...you can get them on a loaner deal from most parts stores, as far as pulleys go not sure how a aluminum one would work and all the newer pumps all use press on pulleys as far as I know
ezstriper is offline
Old 08-05-2015 | 06:25 AM
Thanks for the reply
