Best afr gauge and O2 sensor >
Old 08-05-2015 | 10:01 PM
That's a pretty slick setup then. That'd be ideal for twins without hogging all your dash.
Captain YARRR is offline
Old 08-05-2015 | 10:54 PM
BUP
Bosch has a lot of R&D in 02 sensors so I would look for that and whatever other system to match with. here is another one
also if Bosch does offer a complete kit or anything from Motec
http://www.aemelectronics.com/?q=pro...el-controllers
BUP is offline
Old 08-06-2015 | 12:20 AM
When considering a gauge length of harness/wire is important. I have the FAST dual with 20' cable
ICDEDPPL is offline
Old 08-06-2015 | 07:32 AM
The innovate uses a 0-5V signal to the gauge, so any good quality wire can be used to send the signal to the helm.
apollard is offline
Old 08-06-2015 | 10:33 AM
Originally Posted by Satisfaction
I seen that the NGK is discontinued. this appears to be the replacement. Any feed back? Does it display the same results?
http://www.ebay.com/itm/Ballenger-Mo...item3ce6a3bd58
yes, thats the same as the older NGK, and I only tune with the 02 then remove, the sensors do not like water at all and kills any of them quick...
ezstriper is offline
Old 08-10-2015 | 07:39 AM
Innovate just did a new O2 Gauge , its made specifically for V8 motors
http://www.innovatemotorsports.com/products/dlg1.php
Bulitz is offline
