Help! Engine wont build rpm >
Old 09-17-2015 | 07:15 PM
  #41
SB
Originally Posted by Budman II
duplicate post
Pssst: It's an Edlebrock. See post #5. But either way I think he should check his secondaries. Hehe.
SB is offline
Old 09-18-2015 | 05:04 AM
  #42
I see it all the time..never a complaint about rubber smell..
FIXX is offline
Old 09-18-2015 | 05:05 AM
  #43
Originally Posted by tinkerer
if the engine was that far out of alignment the coupler would stink of burning rubber. And it wouldn't live long.
i see it all the time..never a complaint about rubber smell..BUT I KNOW WHAT YOUR SAYING..
FIXX is offline
Old 04-08-2017 | 01:28 PM
  #44
I know its been awhile since this post, but I forgot to update this last year when I found the problem. So here it is... Pulled the drive, found water was leaking into the bellows, rusted and seized the gimbal bearing. I guess when you buy a used boat, never take the seller at his word the bellows were replaced. So i replaced the gimbal bearing, greased the heck out of it, all new bellows, checked alignment and dropped her in the water last year... Good as new!!!
I would have never thought the gimbal bearing would have caused this issue. I guess, in the process of elimination a bunch of stuff got replaced that didn't need to but hey, she got a great tune up! And I enjoyed her all last summer!
A special thanks to everyone who chimed in when this issue arose.
DjMikeyC is offline
Old 04-08-2017 | 09:31 PM
  #45
articfriends's Avatar
If your timing was at 2 initial and you had to add 10 to get it to 30 and 4 more to get it to 34 total i would think it was off by 14? If your motor was at 20 degrees total on my dyno and we added 14 i would think it would pick up 60+ hp, sounds like your gimbal wasnt doing you any favors but timing wasn't either, Smitty
articfriends is offline
