Best aluminum head? >
Best aluminum head?
Best aluminum head?
Old 08-31-2015 | 03:15 PM
bigboat28's Avatar
Default Best aluminum head?
What is the best aluminum head, dart or afr or other and why? They are going on hp500s possibly stroked to 540s?
bigboat28 is offline
Old 08-31-2015 | 03:22 PM
Here we go!!
indysupra is offline
Old 08-31-2015 | 03:47 PM
F-2 Speedy's Avatar
I think they all flow about the same AFR, Dart, Brodix depending on runner and valve size, I think it boils down to preference and budget
Edit: buy them bare and have an experienced builder put them together to match the cam and other valve train components, jmo
Edit: there's a few threads about this
F-2 Speedy is offline
Old 08-31-2015 | 04:18 PM
GPM
Best price, best quality, best performance, A little more info on how you're going to use them may help
GPM is offline
Old 08-31-2015 | 04:29 PM
PRO COMP
blaquebaja is offline
Old 08-31-2015 | 05:08 PM
SB
300 Magnum kicked some butt in this half way recent BBC head shoot out:
http://www.superchevy.com/how-to/pro...ut-the-o-vs-r/
SB is offline
Old 08-31-2015 | 05:33 PM
Even more interesting to me, is how pretty much all the heads, kicked the GM iron heads butt by a landslide. Also interesting, was the grossly oversized 355 edelbrock, and 360cc trick flows, were still able to maintain some respectable avg and peak torque numbers. If someone on oso said they were going to put a 355 edelbrock E cnc head, or 360cc trick flow, on a 496ci marine "stroker", they would be slapped right thru the computer screen!
Looks like the 4 heads, with CNC porting, were all close to each other power wise. The AFR and edelbrock did have one advantage, with their smaller chambers, probably bumping the compression .75 higher than the dart 335 head, that only made 12HP less, and 20ftlbs less than the afr.
That E-CNC 355 head, looks like it did pretty well. Probably would be a killer head on a 572ci setup. For 1000 bucks a piece bare, fully CNC ported, that seems like a good casting to assemble.
MILD THUNDER is offline
Old 08-31-2015 | 06:19 PM
SB
Take a look at Brodix's newer BB-3 Xtra O 332cc CNC head:
http://www.brodix.com/heads/big-bloc...a-o-exhaust-2/
Then click on "Flow Chart."
That's got a marine 540+cid all over it !
SB is offline
Old 08-31-2015 | 08:42 PM
the 50° intake valve angle may be a little problematic.wonder if they can give a 45° valve seat.
sutphen 30 is offline
Old 09-02-2015 | 02:59 PM
14 apache's Avatar
You can order it any way you want it. probably a few extra weeks.
14 apache is offline
