What happened
#43
Had same problem on 540s, wound up being lifter only had .0005 clearance . Thought it was guide clearance. Dart lifter bores are on the low side of the tolerance and lifters must be fit by brand as sizes differ .
#45
#46
Sorry we put comp short travel lifters in. I have one that is 670 at 5600 then I put flame arestor on and it went to 680 previously with tight lifters this motor only made 550 at 5600. These motors I built with dart iron eagle 320s .
#47
[ATTACH=CONFIG]548146[/ATTACH]
Ill look for the final sheet with the 680 . I made like 10 pulls on the motors. Cam is small ill find you the card . Comp 9.6:1 115 cc no porting just bowl blend after hand fit on the valves .
iles. Makes 680 /680 4700/5600.
