Hp500 carb to efi conversion questions
I currently have a 97 hp 500 carb motor that I am converting over to EFI. I am purchasing a complete take off 500 EFI setup with everything but the distributor. Will I need to install a crank sensor somewhere in this engine or do the 500 efi's use the cam sensor in the distributor only? This is a gen VI 502, and there is a place in the front cover for a crank trigger, but it is currently blocked off. Also, can I use an automotive distributor from a v8 with EFI, or does it have to be a mercruiser distributor?
