Shaft Mount rockers (Brands) >
Old 10-04-2015 | 08:36 PM
Rookie's Avatar
Default Shaft Mount rockers (Brands)
So what is out there for shaft mounted rockers for a BBC Dart Pro 1's.
Jesel, T&D, Comp, Yella Terra, PRW and others??
I need to bite the bullet and buy 2 sets of shaft mounted rockers. After over 3yrs of trouble free boating spinning my engines at 5800-6000 RPM's for miles I finally got bit by my stud mounted rocker arms. I heard a lifter making a little tick and neglected to investigate. I had adjusted cylinder #3 earlier and I had gained 0.008" of lash. (0.015" total) I run solid lifters on my hydraulic cams @ 0.007" cold and 0.010" hot lash. After 3 days of "flogging" my engines up at Hot Boat I had a rocker get loose @ 5500 RPM and walk off the valve tip. This in turn bent my valve, broke my push rod guide and dinged up a piston. No big deal easy fix, but I need to buy some shaft mount rockers now.
I need ratio's of 1.8 IN and 1.75 EX. I see everyone is now moving to steel rockers vs aluminum. And who has the best pricing?
Jason
Rookie is offline
Old 10-04-2015 | 08:56 PM
GPM
You might check out Crower Stainless
GPM is offline
Old 10-05-2015 | 09:31 AM
Have you considered running hyd roller lifters on your hydraulic roller cams?
My buddy had some engines in his boat that were built up in sw michigan. They had some reed hyd roller cams, with solid roller lifters. Ultimately, a similar thing happened. His polylock came loose, rocker backed off, pushrod bent up, and blew the head gasket. At that point, he rebuilt both engines, switched to some custom bullet hyd roller cams, crower hyd roller lifters , crower stainless stud mount rockers. Been running good now since 2010.
MILD THUNDER is offline
Old 10-05-2015 | 12:20 PM
Rookie I assume that you plane on running at or over 6K on a regular basis? and have a decently stout cam profile.
abones is offline
Old 10-05-2015 | 12:31 PM
Rookie's Avatar
Nope, but I've heard that is been done before, lol
It was my neglect and I understand that I had a hand causing the problem. As stated earlier the engines have been trouble free for years. I know I need to get some shaft rockers because of the length of time and frequency I turn high RPM’s. I actually thought that I lost a cam lobe, but the cam looks excellent no signs of any wear.
Rookie is offline
Old 10-05-2015 | 12:39 PM
Rookie's Avatar
I planned on running 5800, but the boat just kept running stronger and stronger the more I messed with it. Actually the cam is kind of mild. I use to run a 252/264 solid cam and now I'm in the 235/240 range. Just an RV cam
Rookie is offline
Old 10-07-2015 | 02:18 PM
I run a pretty stout hydraulic roller cam with Morel Lifters and Crower Pro Magnum 8560's on studs with a JOMAR stud girdle. I run up to 6k myself and typically well into the 5's even when cruising. I have almost 200 hours on them and they are still like new. With all the stories of broken parts I check my engine regularly.
ThisIsLivin is offline
Old 10-08-2015 | 08:59 PM
Jason
We have the same rocker ratios and use the Jessel shaft rockers. Our experience SpinTron testing was the 7/16" tapered heavy wall pushrod was the game changer for valve train stability/longevity. Unless you are racing, the shaft rockers are likely overkill.
BenPerfected is offline
Old 02-06-2016 | 05:48 PM
Rookie's Avatar
TTT
So, I have been doing my due diligence and I have been looking at the these LGM shaft rockers. Apparently they are a good piece for reasonable money. Someone said that they were developed by Probe? And then sold to someone else. I have found out to stay away from the PRW and Speedmaster shaft rockers.
http://lgmrnd.com/index.php/header1/...ft-rocker-arms
Rookie is offline
Old 02-06-2016 | 05:57 PM
GPM
Not that it matters, but I still like the Crower Stainless shaft rockers versus aluminum. Over kill or not, I think it's very rare to find a rocker just before it breaks, I would rather run the best I can find.
GPM is offline
