What do these bearings tell you? >
Old 10-15-2015 | 10:05 AM
  #141
Originally Posted by MER Performance
horsepower1 (Scott) Please remove your "Like" from my "Post"
Nice way to welcome a new knowledgeable guy to the site.
kvogt is offline
Old 10-15-2015 | 11:08 AM
  #142
bck's Avatar
bck
Charter Member#568
I'm using a different builder this time around so hopefully all goes well this time. I haven't even mentioned this to the original builder, I'm not looking for anything from him. Time to move on from this I guess and maybe post some pics of the new build.
Straight bottoms and flat decks
bck is offline
Old 10-15-2015 | 11:20 AM
  #143
SB
Originally Posted by apollard
The temp sensors read vapor temps with a very slow response time. So, if you were not getting water flow, they would have been surrounded by steam / air and read incorrectly. It takes a long time for the heat to get high enough to read on a temp sensor that does not have water on it. I burned up a car engine when it dumped the water quickly - temp sensors got into the hot range after it started showing signs of damage. Even after I stopped, it took a long time for them to hit the overheat range on the gauge.
X 2.
See this all the time at work. If one at my shop does not check coolant level in radiator for many drivability issues (not just heating/cooling), you get a dope slap from me. And sometimes more. LOL.
SB is offline
Old 11-08-2015 | 07:12 AM
  #144
bigboat28's Avatar
Any pics? Are your new motors done yet?
bigboat28 is offline
Old 11-08-2015 | 10:06 AM
  #145
bck's Avatar
bck
Charter Member#568
Short blocks are done. It took a while because I was trying to decide if I wanted blowers. Now waiting on cams.
Attached Thumbnails What do these bearings tell you?-imag1233.jpg   What do these bearings tell you?-imag1323.jpg   What do these bearings tell you?-imag1311.jpg
bck is offline
Old 11-08-2015 | 10:55 AM
  #146
bck's Avatar
bck
Charter Member#568
Attached Thumbnails What do these bearings tell you?-imag1322.jpg   What do these bearings tell you?-imag1314.jpg
bck is offline
Old 11-08-2015 | 11:01 AM
  #147
looking good. How much power you looking to make?
MILD THUNDER is offline
Old 11-08-2015 | 11:11 AM
  #148
bck's Avatar
bck
Charter Member#568
Well, the heads are only the 305s and I'm sticking with the 4150 flange Vic Jr. I'm only changing the cam. I'll try a dominator with an adapter on the dyno to see if it makes a difference. No real hp goal. That being said, they will be 8 ci bigger, about .5 higher compression and spin them a couple hundred rpm faster. Cams will still probably be on the milder side. Although it didn't work out these engines were supposed to be way over built for the power so they'd stay reliable and last.
bck is offline
Old 11-08-2015 | 12:58 PM
  #149
"X" hatch scotchbriting is an old school process to leave microscopic scratches for oil retention in the bearing. Local well known and respected engine builder taught me that trick years ago. I still do it to this day, however, its effectiveness is not always seen agreeable amongst different builders.
Cory H is offline
Old 11-08-2015 | 01:15 PM
  #150
bck's Avatar
bck
Charter Member#568
Is that how it looks? Maybe that's why it was done, nothing else really explains it
bck is offline
