Saginaw to Brazilian actuator question. >
Old 11-12-2015 | 07:19 PM
"If this is the case you have to find a male fitting that goes into the actuator with and female side that will allow you to screw in your older style power steering line fittings. Hope that makes sense. Or the other way is to update your power steering lines."
"Like I said you can only back fit so far, after that you are on your own trying to find fittings to make the older power steering line fittings to screw into the newer style actuators. It can be done if find the correct adapters to do so or have a hose / hydraulic company make you some lines that work with the new actuators.."
That is where I am, If I had the quick connect (part# 22-865415) #5 on drawing I could try to find other (female side) part I guess from hose maker.
Well I was hoping for a simple kit with the adaptors, always the little simple chit that sets you back. It just seems crazy to spend $150-$200 for darn hose.
Off to hyd. hose shop to see what they can do. I'll keep you posted.
Thanks all for the help
GLENAMY 242SS is offline
Old 11-12-2015 | 07:37 PM
BUP
Yes thats were they left you hanging with the older style apps. Thru Merc also there is a whole updated kit with newer actuator and hoses and fittings attached but it costs around 500 to 600 bucks.
BUP is offline
