Is filling fuel tank really necessary when winterizing?
I fill my tank full with 91 Non Ethanol plus stabilizer
To hard to pump 100s of gallons of gas out, no where to put it, plus I drive mostly diesels
Then I spike the fuel in the spring with 112 race fuel
Full or empty are both good options but I like the addition of using NON ETHONAL fuel no matter which way you choose
If you do run your tank empty in the fall, and you have EFI, be careful in the early spring. Many times the pumps in early spring still have 'winter mix' fuel which has a lower boiling point and can cause vapor lock very easily. I have learned this the hard way on my twin 500EFIs over the last few years. I leave about 1/4-1/3 tank in there stabilized. Enough to get me through the early spring until they start carrying 'summer mix' fuel.
Ive heard you can also 'spike it' with some higher octane to prevent this, but have not tried it myself.
Used to always store full with Stabilizer when 100% gas was norm. Now, with E10 it's empty as possible with Stabil. I used the new Stabil 360* ethanol treatment this year which supposedly protects the tank! lines etc... From ethanol associated corrosion.
coolrunning racing
Non ethanol fuel can be treated as it has been for years. Stabilize and fill. E-10 as per Merc, when at all possible empty the tank. You can not stabilize E-10 and have fuel in the spring that meets engine manufacture minimum octane ratings. The stabilizer can treat the base fuel, lube the tank walls and ect, but it can not retain the ethanol which will evaporate in 3-5 weeks and or absorb moisture. So run it low as possible stabilize, winterize and the pump it out. This has been our procedure since the implementation of E-10 and have not had one fuel related issue with my customers that follow this procedure.
E-10 has a short shelf life 3 weeks for 86 and up to 5 weeks for 93. This is why you can not fill it and store it stabilizer can not stop evaporation and water absorption.
coolrunning racing
I also spent a better part of an hour with a chemical engineer from a major brand of fuel stabilizer and he confirmed that you can treat it for minimizing the side effects but nothing can be done about the evaporation / moisture absorption.
I've stored full, I've stared empty and I've stored in the middle. I've stored with and without fuel stabilizer. Never had any trouble either way and it's always been ethanol fuel. My fuel filters never have any discernible water in them in the spring.
I think this topic is over analyzed.....
I found my fuel tank to be leaking after sitting for a while filled to the top. +1 for pumping the tank dry right here!
...well I guess if i never filled it i wouldn't have noticed the leak until spring. Which would have sucked.
