Ignition dead on 525sc >
Old 11-11-2015 | 04:14 PM
Default Ignition dead on 525sc
The port engine lost an ignition module. Need some advice on a replacement module. Has anyone tried the Daytona Sensor module for this motor? Or should I try to find a stock module.
Baja8808 is offline
Old 11-11-2015 | 06:38 PM
The pick up module in the distributor ??? or the ignition advance module???
Griff is offline
Old 11-11-2015 | 06:47 PM
The advance module.
Baja8808 is offline
Old 11-11-2015 | 07:30 PM
You talking about the daytona sensor programmable marine ignition? Yes, I have. You can do some cool things with it. It also has a stock 525SC advance curve built into it as well.
MILD THUNDER is offline
Old 11-11-2015 | 10:22 PM
I don't know anything about the Daytona module set up.
There are a few 525SC TB IV Modules( 814295A1)on ebay for $200-300
I assume you swapped modules between engines to verify it was bad???
Griff is offline
Old 11-12-2015 | 09:08 AM
Thanks Mild.. Griff, yes I swapped them and it was the module..
Baja8808 is offline
