Melling 10778 oil pump question >
Old 11-22-2015 | 04:17 PM
Full Force's Avatar
I didn't want to cut into crank since specs were ok, just all over.... is what it is but I would do different cranks next time...I was able to get real cheap pricing on Eagle that's why I used them. should have not done that..
Originally Posted by donzi matt
I thought it has been common knowledge for a long time that Eagle's tolerances were all over the map. I'm surprised your machinist didn't true things up before installation. I'm surprised your oil pressure is as high as it is.
Full Force is offline
Old 11-22-2015 | 04:26 PM
Originally Posted by ICDEDPPL
I`ve lost about 15 psi with spring oilers , 50ish psi wide open (have high volume melling pumps) . Bearings look fine but I get some anxiety when the pressure falls below 18 psi @ hot idle.
Looking into going with Schumann pumps this time around , or titan but those are some $$
Could you restrict a bit of the oil to the spring oilers. You could use some nitrous jets to regulate the oil to oilers?
indysupra is offline
Old 11-22-2015 | 05:56 PM
Originally Posted by Full Force
mains average .0032-.0035 with a .0040 rear, rods .0025-.0028 average, with Eagle it's all over, you remember the findings when we talked I am sure, I would have used Scat if I knew Eagle was like that at the time..
lifters are .0022 across the board.
I never see less then 25 at idle no matter what, always shows 70 when running with oil temps in 220 range
imo those are perfect numbers for a endurance marine engine that uses a oil pan with a minimum of 8 qts and 20w50 wt oil.
mike tkach is offline
Old 11-22-2015 | 06:35 PM
Everyone uses carb jets. The leakage from the oilers running wide open is way to much. Even when you "jet" them down they still spray oil like crazy...
Black Baja is offline
Old 11-22-2015 | 09:19 PM
It`s a 1/8 line going in and I would assume properly sized jets already built in.
ICDEDPPL is offline
Old 11-23-2015 | 03:39 AM
You can run both sides off of one small jet and it will still oil the springs like crazy and you will not have oil pressure issue.
Old 11-23-2015 | 05:19 AM
Full Force's Avatar
oil pans are 12QT to ensure good oiling.
Old 11-23-2015 | 05:26 AM
Full Force's Avatar
You can see oil pressure, rom and oil temp here from October run. Don't mind te chitty looking gauges, still need to replace them lol
[ATTACH=CONFIG]547925[/ATTACH]
Old 11-23-2015 | 08:44 AM
I`d be afraid that it wouldn`t be enough oil volume to spray the springs. That it would dribble out instead of a nice stream. ??
I need some clear valve covers :-)
ICDEDPPL is offline
Old 11-23-2015 | 08:53 AM
donzi matt's Avatar
Might be a dumb idea, but how about when you reassemble it you run the pump off of a distributor priming tool run by a variable speed drill with no valve covers on? Then you could jet down your oilers to a point where you are comfortable with the spray and bring up your oil pressure. Lots of variables with regards to oil temperature and viscosity, but maybe you can learn something from the experiment.
donzi matt is offline
