Rods
Old 12-17-2015 | 08:19 PM
  #171
Mild, think about this- your e-bay rod's spot face isn't flat but you don't know that, so you torque it to 100# once. Well guess what now the spot face is flat and normal to the bolt axis, luckily the cap material was India finest bubblegum. But hey! You torqued that SOB!
Did you introduce any preload? Nope. You're hosed and won't know until it's too late.
EDIT- we were typing similar cases at the same time. Torque lies.
Cole2534 is offline
Old 12-17-2015 | 08:25 PM
  #172
Think about this. Earlier we got 160,000psi stress in 0.0055". That equates to some torque, say 120 ft/lb. If the spot face deforms .001, and the cap/rod crush a .001 during our 120# torque we've only imparted .0035 elongation - 45% less
But hey! the torque wrench read the same!
Can anyone tell that I like fasteners?
Cole2534 is offline
Old 12-17-2015 | 08:38 PM
  #173
Originally Posted by Cole2534
Rocker studs are the ones that weird me out, they have no shank length in a highly stressed environment.
Very true. I recently rigged up a dial indicator on a poly lock with hardware in place (rocker, spring, pushrod, etc). Just rolling the engine over by hand, I had about .002 of stud deflection while valve went thru its lift cycle. With just my thumb pushing against the polylock, I was able to get about .004 deflection.
MILD THUNDER is offline
Old 12-17-2015 | 08:53 PM
  #174
Full Force's Avatar
I think I just pizzed my pants LOLOLOL
Originally Posted by ICDEDPPL
I told my wife I was gonna bolt the $hit out of her tonight with my Richard
Full Force is offline
Old 12-17-2015 | 09:08 PM
  #175
sure glad their is no over thinking going on here,lol.
mike tkach is offline
Old 12-17-2015 | 10:33 PM
  #176
Originally Posted by sutphen 30
I guess most of the diy guys are just getting lucky because there sure isn't that much talk about tips failures from bolts.hydrolocking and reversion,yes,but cycling rods bolts.no way
And I've seen and done a ton of Builds that don't do that.everything from cheap stockers,eagle's to Oliver and full out drag race aluminum rods(and these guys go to 9600rpm).
The lube on the threads and back side are more critical as well as stretch if that's the process you are going to use.
u sure
I'CE is offline
Old 12-17-2015 | 10:48 PM
  #177
Originally Posted by I'CE
u sure
You saying the bolt cycling is necessary, or that theirs been failures ?
Old 12-18-2015 | 07:15 AM
  #178
Originally Posted by Interceptor
I know I'm being a dick but.....................Just to be a technically correct those fastners you're all talking about are called screws not bolts. A screw goes into a threaded hole in the mating part, a bolt is secured with a nut.
and
I'd still be equally concerned with bad threads in the rod causing a issue vs the screw.
You're absolutely right and to be even more accurate, they're called cap screws, not just screws.
horsepower1 is offline
Old 12-18-2015 | 07:28 AM
  #179
If any of you are really interested in learning about fasteners, there is a book that is my Bible on this stuff and it's written by a guy named Carroll Smith, called Nuts, Bolts, Fasteners and Plumbing. If any of you have an ARP catalog, you'll see a tribute to John Carroll Smith somewhere in the beginning. He was one of the early contributing engineers at ARP and worked throughout the racing industry. This book is a great read for anyone interested in this sort of thing. It's out of publication but I'm sure you can find copies on EBay and such.
Old 12-18-2015 | 07:32 AM
  #180
F-2 Speedy's Avatar
This is the reason for stud girdles, to minimize the deflection and help stabilize the valve train, I'll tell a little story that BS told me and if it wouldn't have came from his mouth in person I doubt I would of believed it. So he's building a pretty healthy small block for one of his customers, made a couple pulls and it made good power, then the guy shows up with some girdles and they get bolted on, another dyno pull and gained 15-20hp, he didn't believe the numbers so he pulled them back off and the HP gain was gone, True story from the man himself with his father Bob as a witness.
F-2 Speedy is online now
