Oil Pressure Question... Nothing broken but chasing an oddity
Wouldn't the Oberg cause the reverse then if it had no restriction? Wouldn't that allow oil to pretty much free-flow further reducing pressure? The engine was showing near double the oil pressure with the Oberg. I would think that the bearing clearance would really allow oil to leak with that kind of pressure. Thoughts?
Earlier post... Autometer Pro Comp mechanical.
I still don't get it with regard to the pressure drop. The Oberg still creates a restriction. It flows more than regular filter but it's still there.
Now take the plug out and feed the oil filter with a 1/16" line start the motor would there be any pressure? Yes but minimal.
Now keep stepping your line size up to feed the motor. The more flow you get to the bearing the more pressure you will have... Less restriction = more flow to the bearings which makes more pressure.
Sorry I missed that. That kind of rules out the sender/gauge in boat. The filter will have a pressure drop, but not more than a few psi, especially if the bypass isn't plugged. The fittings, lines, and oil cooler have some restriction and will drop pressure. 45-50 does seem low, but your setup is different than it was on the dyno and you will see less pressure with the added restriction.
Oil pressure will drop as a result of a couple things: more bearing clearance, or an increased demand on the system like oil lines, coolers, remote filters, etc. or both....
The filter is the first thing after the oil pump, but pressure is usually taken somewhere after the filter. If the filter has enough restriction, it can effect the oil pressure but this is seldom the case unless there is something wrong with the filter. Since the pressure is read after the filter, more filter restriction will cause lower oil pressure, just like a clog in the line. However, since pressure is taken before the bearings, (and pressure is simply a measurement of resistance) the more bearing clearance you have, the less pressure there will be, all else being equal.
Interestingly, the pressure really doesn't change. Even with heat. I ran it for about 30 minutes in the 3K rpm range and never saw much of a pressure drop. Maybe 5 psi if that. Revving it a little bumps it right up on 50 PSI. I've heard of filters collapsing and causing a drop of 20 PSI or so. I haven't gone into the filter yet (tomorrow), but the newer Delco filters have reported similar issues (they're made rather cheap).
I'll know more tomorrow after playing with it some,
are you sure the oil lines are routed correctly?at this point i would remove the merc system and install a good quality oil filter directly to the engine block and note the oil pressure.if the pressure is still low the next thing i would do is remove the engine and inspect every clearance in that engine.you stated that you don,t know for sure what the bearing clearances were so at this point you need to find that out.i can tell you from past experiance that the electric gauge in the boat do not always tell the story.hook up a mechanical gauge when testing the engine in the boat.good luck and i hope it turns out to be a simple fix.edit in. horsepower1 is correct,the chevy v8 engine will have no oil pressure until the oil flows through the filter and back into the engine.
