Exhaust systems >
Exhaust systems
Exhaust systems
Old 12-30-2015 | 07:34 AM
Originally Posted by mike tkach
i think a not so good exhaust manifold will hurt a 650 hp n/a engine more than a 950 blown engine.the blown engine does not rely on the scavenging like the n/a engine.
While a blower engine may not benefit from a tuned exhaust, it's processing a lot more air and fuel and still needs a good exhaust system and will benefit just like any other engine. The manifold, while not tuned, may not be as much of a restriction on the smaller engine as it would on the larger blower engine and that restriction will kill power on the blower engine.
horsepower1 is offline
Old 12-30-2015 | 07:38 AM
Originally Posted by MILD THUNDER
I had an engine masters magazine where they did a header shootout on a bbc . I think it was a 572 ci making 700 plus. I recall them trying several different headers with various ID's. I recall there being a pretty good difference from a 1 3/4 to 2 1/8. I dont recall the exact power numbers, but it was pretty significant. Ill look and see if i have it still.
I've done many header comparisons on the dyno. Lot of our customers order custom headers with their engine combinations. We do initial testing with the dyno headers but will always do the final pull and tune with customers headers. One thing I can say about headers, especially with NA engines; bigger is not always better.
Old 12-30-2015 | 07:44 AM
you are correct on the imco manifold not being right out of the box,i spent several hours with the die grinder to get it gasket matched.i had the imco power flo,s on my cat.they were 950 on the dyno with dyno headers so in sure their was a little power loss with the imco,s but they ran very good.the engines were 548s with dart 320s.
The IMCO's I've worked with seem to be good up to about 850-900hp. After that, they're going to start hurting power over something tubular and more tuned. I did a blown pump gas 540 that made 1020 hp with dyno headers, but when in the boat with the IMCO's the engines performed to right about 900 hp, given rpm, prop and pitch. This kind of goes to the above post where there's no way the IMCO's would kill 100hp on a NA 540 even over a set of tuned headers, but they kicked the blower motor in the nuts.
Old 12-30-2015 | 08:01 AM
I can believe that entirely!
Good example is stainless marine gen 3 exhaust. Not to be confused with their standard manifold. The gen 3 is huge. Makes the imco,gil, emi stuff look tiny.. Giant elbow, 5 inch tailpipe, etc. That exhaust worked very well on big power blower engines, as thats what it was designed for, and has outperformed even some big headers on those engines. Now, i would not chooose that for a N/A exhaust .
My stellings "green" headers were designed for the merc 575. Which was a 540ci making 575hp in late 80s. 1 7/8 primary. In a recent conversation with a well versed offshore builder who is familiar with those headers, said they certainly can be hindering power a bit, even on my 800hp blower engines.
MILD THUNDER is offline
Old 12-30-2015 | 09:29 AM
bck's Avatar
bck
Charter Member#568
For support I have another set of trim rings on the inside of the transom with a thick non stretching rubber/ canvas type material. It is flexible to allow movement but not stretchable so it supports the pipes at the transom.
Straight bottoms and flat decks
bck is offline
Old 12-30-2015 | 09:56 AM
vintage chromoly's Avatar
Another thing I was wondering about.....
My "dry" tails have six 3/8" water outlets right at the tip. I was considering welding those shut and welding in bungs near the ends of the tails and dumping the water that way.
Is there any advantage to either way of expelling the water? Can the water migrate back up the tailpipes even when it's introduced at the very tips of the pipes?
vintage chromoly is offline
Old 12-30-2015 | 11:06 AM
SB
Furthermore:
When exhaust hit's the atmosphere, an energy wave is sent backwards towards the exhaust valves. This is why collector length is very important, yet no one seems to give a schit about it.
SB is offline
Old 12-30-2015 | 11:26 AM
If you are going to weld the tailpipe shut 100 percent what you need to do is cut the outer sleeve off of the tailpipe first, then cut 1" out of the outer tailpipe and then slide a 6" piece of 4.5" wet exhaust hose up over the existing outer tailpipe then slide the outer piece you cut off back on and weld it up. This allows expansion of the inner pipe because it's much hotter then the outer and if it's butt welded at the end it'll always be prone to crack. Atleast I have experienced this. All this is inside the bilge obviously. Use the wet exhaust hose as a "coupler" if you will except the inner pipe will be continuous you're simply holding water from spraying out. Then add your dumps in the tailpipes. You should also consider drilling a 1/4" hole in the bottom of the outer pipe outside the boat so that way the bottom of the tailpipe can drain when you shut the engine down. I've had great success with this tailpipe setup for a long while.
And as far as your question about can your engine pull water back up from the very end of the tailpipe? Absolutely. I know of a SVL team that had issues with water reversion on their sealed 525 with 100 percent dry tailpipes. They caught on their camera systems at idle the dumps were too close to the tailpipe and water was getting sucked over and back up the dry tail at idle. Wouldn't have believed it if they didn't show me the video. They moved the water dump and the problem went away.
mickeymcclgn is offline
Old 12-30-2015 | 11:59 AM
JMO . . . Loud pipes save lives and engines
endeavor1 is offline
Old 12-30-2015 | 01:38 PM
Anyone ever test say a stainless marine, emi, imco, style manifold against a header at the 650-800hp N/A range ?
