CFM on the 500 EFI Heads?
.300=197/150
.400=233/174
.500=258/184
.600=280/187
.700=287/187
ERRONEOUS NUMBERS. THROW THESE OUT THE WINDOW. REFER TO CALLING MERCURY RACING TECH LINE, OR MARINE KINETICS TO SEE WHAT A STOCK 500EFI HEAD FLOWED ON THEIR FLOW BENCH BEFORE PROCEEDING
Everyones flow numbers will be different. Those numbers were tested on a 4.500 bore, no pipe on the exhaust. Gives you an idea. Going to a Dart, AFR, Brodix, RHS, Trick Flow, etc, is a sure way to see power increases. Those old Merc Iron heads, were pretty poor stock, compared to a modern Hi performance aftermarket head.
When comparing flow numbers, keep in mind the bore size the heads were flowed on, whether or not the exhaust had a pipe on it, etc. Also, was it an actual out of the box head, or did it have a trick valve job for magazine promotion, etc .
http://users.erols.com/srweiss/tablehdc.htm
.200=149/117
.300=197/150
.400=233/174
.500=258/184
.600=280/187
.700=287/187
.300=197/150
.400=233/174
.500=258/184
.600=280/187
.700=287/187
.200=149/117
.300=197/150
.400=233/174
.500=258/184
.600=280/187
.700=287/187
.300=197/150
.400=233/174
.500=258/184
.600=280/187
.700=287/187
plus,I guess at rebuild time,you should get a trick valve job like all the after market heads get .
most do raise the exhaust port.but sometimes,trimming the hole a little bigger gets the pipe thru.its a matter of trying after committed to new heads.
BB Chevy heads have two different intake ports and the "good" port is always the advertised port. The "bad" port can be 20+ cfm below the "good" port through mid lift numbers. Just a valve job on those heads can be worth 20 cfm so comparing these flow numbers with another set of the same heads is pointless. A pipe on the exhaust will also make a big difference on the flow bench.
