CFM on the 500 EFI Heads? >
Old 01-05-2016, 10:24 AM
I appreciate the responses... What is the intake runners cc? Is it 310, 325, or 345? I know the 525 EFI is 315
F1-00 Racing is offline
Originally Posted by SB
You are adding emotion to my post when there wasn't any.
If we need flow #'s, we should then get them from the correct head. That's all.
Yea yea i know. Same guys once again chiming in to discredit anything i post.
I apologize. I dont have a brand new out of the box mercury valve jobbed untouched 500efi head to bring to my guys shop for flow numbers. Ill try better next time for you !
MILD THUNDER is offline
Old 01-05-2016, 10:26 AM
Originally Posted by Gimme Fuel
I'm interested to see what those RHS/Enginequest 320's do
Ill pm you that info when i get them flowed, and what they flow after a few mods.
Old 01-05-2016, 10:39 AM
Mild,
I have new sets of Dart 308 iron eagles. I did a minor port match to the exaust gasket. I left the bottom untouched for an anti reversion dam and left about a 1/16" all the way around so its not really matched, just closer. I don't expect noticeable gains here.
I did however very carefully clean up the combustion chamber including the heavy ridges around the valves seats, smoothed them and the chamber out. I did not change the shape of the chamber other than taking off the ridges around the seats. I assume this is kind of what is done to the cnc chamber of the dart pro 310?
I would be very interested to know the before/after flow numbers and what type of porting/head work is done.
Thanks.
Mr Maine is offline
Old 01-05-2016, 10:46 AM
Ill carbon copy you on that PM.
Looking forward to your build results on that combo. When its done, can you PM me back how you made out ?
Old 01-05-2016, 10:53 AM
SB
Received 3,116 Likes on 1,403 Posts
MT. Post #1 to this thread.
Originally Posted by F1-00 Racing
Does anyone know the CFM on the Heads for the Mercury 500 EFI? Thanks in advance for any insight
SB is offline
Old 01-05-2016, 10:59 AM
I didnt see post number 1. Thanks for clearing that up. Maybe you can post what a stock untouched 500efi head flows. Then, we can discuss the variances between different flow benches, and how those numbers may also be off from what the OP's heads actually flow. I went back and edited my post with the flow numbers i put up in an effort to give the OP a ROUGH idea of what those style heads flow. Do i believe the numbers afr or dart put on their website for flow ? Absolutely not.
Want precise numbers, take your own heads to a bench and flow them.
To the original poster F1-00 racing, are these heads bone stock, or have they been redone at any point ?
Old 01-05-2016, 11:24 AM
bone stock
Old 01-05-2016, 11:31 AM
Originally Posted by sutphen 30
when strippoker had his heads flowed,they were in the 300's for intake and 200's for exhaust.not sure wer you got those numbers,just saying.
plus,I guess at rebuild time,you should get a trick valve job like all the after market heads get .
Heres strips information. Make note, these heads were not bone stock according to his posts. But anyway...heres the numbers he posted, with 2.25 valves on those heads and some blending work , and possibly different valve job then stock.
Attached Thumbnails CFM on the 500 EFI Heads?-screenshot_2016-01-05-11-27-51.jpg   CFM on the 500 EFI Heads?-109034d1102061538-hustler-500efi-engine-tear-down-build-up-hustler-head-flow-380.jpg
Old 01-05-2016, 11:41 AM
appreciate it...
