Builder used different cam than specified. >
Old 01-17-2016 | 07:23 PM
  #81
Just an FYI....
I just sent my risers back to Eddie Marine to be modified..
They quoted me $350 to change the water outlet to their "water dam" style and extend the inner pipe 3" past the outlet...
Boatally Insane is offline
Old 01-17-2016 | 07:54 PM
  #82
Originally Posted by JRider
I am not discounting that with the specified cam, I am discounting the generalization of adding a 110hp on a cam that is much better suited for an NA. The 132561 is a 525sc cam, and would not be a bad choice either. The 110 LSA is sending power out the pipe.
There are certain scenerios were a tighter LSA, can make great power on a blown pump gas deal, but this engine build certainly isn't one of them, with a small 177 blower. He cannot afford to throw any boost away with that little blower.
MILD THUNDER is offline
Old 01-17-2016 | 07:55 PM
  #83
Originally Posted by 79formula
I would say a supercharger is a legitimate power adder.
yes it is but my point was that your builder doesnt even remember your build and then just says that it will add 110 hp. engines are complex and if you just go by what someone says every one would have 800 hp daily drivers. so far your builder doesnt seem to have much interest in what he does or what his customers think.
compedgemarine is offline
Old 01-17-2016 | 08:10 PM
  #84
Originally Posted by Boatally Insane
Just an FYI....
That's cool that they can do that and at a reasonable price. That said, with my original $146 cam it is unnecessary.
79formula is offline
Old 01-17-2016 | 08:12 PM
  #85
racinfever's Avatar
You should change the cam, one way or another !
racinfever is offline
Old 01-17-2016 | 08:19 PM
  #86
If I have to buy the cam myself and throw it in, I will. Do I have to degree the 134561 cam or can I just bolt it in straight up and go?
Old 01-17-2016 | 08:29 PM
  #87
vintage chromoly's Avatar
You need to degree every cam that goes in any engine. Period!
vintage chromoly is offline
Old 01-17-2016 | 08:34 PM
  #88
blue thunder's Avatar
I just did a cam swap on an engine this week and the cam was 4 degrees retarded as installed. Like vintage said, always degree a cam, way too many possible error points not to verify it is correct..
blue thunder is offline
Old 01-17-2016 | 08:35 PM
  #89
SB
Just an FYI....
Sounds great and a good def pic, but too bright for me to see inside. LOL. Can you try another pic ? That would be great as this option may help ton's of people.
SB is offline
Old 01-17-2016 | 08:39 PM
  #90
I guess 4* retarded would have that exhaust valve closing later, increasing the reversion risk.
