Iron VS Aluminum heads >
Old 02-19-2016 | 06:05 PM
  #211
14 apache's Avatar
Originally Posted by horsepower1
Too many generalizations and assumptions regarding port volume and head performance. Head performance comes form flow and velocity. They have to work together. The velocity factor comes form the minimum cross sectional area of the port and on a conventional BB Chevy head this area is usually just past the push rod "pinch". Mean flow numbers are what they are, and the smaller the cross section, the more velocity the port will have. Old school BB Chev heads like the OEM rectangle ports and older Brodix and Canfield heads that were designed after that have a lot of volume in the front of the port with large minimum cross sections ( big rectangle port) but have relatively small bowls. Then you can look at something like a Dart or AFR and you see the port is a lot smaller in the front with smaller minimum cross section and more of the volume is in the bowl, after the short turn. You can have three different 320cc cylinder heads and have three completely different velocity profiles and three completely different power potentials. I just finished a set of AFR 315's and did a 2.300 intake valve upgrade with a lot of bowl and short turn work. I didn't change the minimum cross section at all because it's already a little on the big side for what i want but the work increased the airflow significantly, so now the velocity will be closer to where I want it through the minimum. These heads are probably in the 325cc range now, bit with the small cross section of the 315 and they will out flow the 335 cnc. My guess is (without measuring them) the EQ heads are probably relatively small in the front and will work fine on a 500+ci engine with the right cam. They're not ideal, but for the price could be made to work real well. I wouldn't lose a minute's sleep over using them.
Here's the 315's I'm doing. I'm leaving the burr finish.
My office...
For those interested in numbers:
Flow: (4.50 bore, 2.125" pipe on ex)
right / left / ex
.2 165.5 / 164.2 / 120.8
.3 249.2 / 245.6 / 204.4
.4 306.9 / 300.5 / 249.7
.5 351.7 / 344.7 / 277.3
.6 382.9 / 364.2 / 290.2
.7 398.1 / 382.9 / 302.7
.8 404.2 / 394.6 / 313.4
.9 411.0 / 401.9 / 318.2
1.0 412.1 / 405.6 / 321.7
Right port on 4.60 bore (just for reference to AFR's numbers)
.2 166.0
.3 250.7
.4 312.4
.5 357.0
.6 389.3
.7 403.0
.8 406.2
.9 412.8
1.0 415.4
Looks good how many hours to do a pair? Have you ever tried the brodix BB-3 332 XTRA O just wondering.
14 apache is offline
Old 02-21-2016 | 10:40 PM
  #212
Originally Posted by Panther
I've read a lot of those posts as well, some good data. Articfriends has a ton of time on MPI's and seems to be the most knowledgeable with it from a home grown perspective.
I'm focused on my specific build though and those with specific hands-on experience with my setup. Thanks anyway for the info.
Frank, why don't we stop playing games. You are here to #1, basically look for a combination you could copy, for your own engine build, and #2, asking questions to myself and others, to play your agenda over on boatfreaks with the others. You have alot of ballz to criticize my advice, the guy who's wanting to dismiss a cylinder head on a build over 12cc of port volume, with no discussion of any other parameters of the cylinder head (which foxwell clearly explained here), and dismissing another cylinder head over 7cc worth of chamber volume (because its been CNC ported). Maybe you are unfamiliar with something called milling a cylinder head. But, I suppose for a guy who is looking to "copy" someone elses build, and stick to what he can "bolt on", I am not surprised. You're posts clearly show you have minimal understanding of engine design, and the fact you are playing games acting nice over here, and a wise azz over there, show your true colors. Please don't give me the bullchit of saying "thanks anyway for the info".
Attached Thumbnails Iron VS Aluminum heads-panther1.png   Iron VS Aluminum heads-panther2.png   Iron VS Aluminum heads-panther3.png
MILD THUNDER is offline
Old 02-22-2016 | 12:57 PM
  #213
Panther's Avatar
Frank's Marine Service
Joe, I really don't have time for your BS. Check the dates, it was posted AFTER you made continual digs and attempts to put down anything I posted for a number of weeks. You've been making insults and insinuations on my posts and others long before I posted anything over there about it.
I put my post up over there because I was interested in hearing FACTS based on EXPERIENCE, not a debate over what you may think will work sitting behind your keyboard. You're exactly right, I was looking for a proven combination and I was not looking to reinvent the wheel. Not having worked with the MPI before, I'm not going to pretend to be an expert and come up with a package for someone. If YOU had in fact put together a package like the one I'm doing, I think you would have shared your experience but from what I gather, you never have. When you don't have experience with something, I don't suggest pretending to be an expert on it. By sitting here and insinuating I don't know anything about engine design is quite funny because you have limited expertise in that area as well. Neither of us are engine builders or designers.
The funny part in all this is after all said and done the owner has purchased the EQ heads and decoded tp go in that direction due to price point. That had absolutely nothing to do with your input as much as I'm sure you would like to think it did.
I believe you have had an issue with me since I questioned your friends water plumbing technique on Facebook a few months ago. During that exchange you wanted to argue with me over instant message so I agreed to disagree and move on. I still wouldn't plumb an engine with the water going through the exhaust manifolds before entering the engine unless maybe it was in frigid waters of Novascotia. Ever since then, it seems there's always been an issue. Quite honestly, I don't have an issue with you. You seem to have one with me so don't get upset when I react.
Have a nice day!
Panther is offline
Old 02-22-2016 | 02:39 PM
  #214
Yea, looks like you guys have quite the group of engine builders over there in that forum.
This was MY thread, in which you asked for input several times. If you dont like me, or anyone else here, i have a pretty good idea on what you can do with your questions.
Have a good day!!
Old 02-22-2016 | 04:33 PM
  #215
By the time I do the valve jobs, the port work, surfacing, final blending, facing and back cutting valves, honing guides, etc and final clean and assembly, I can tie up a good 35-40 hrs in a set like this.
I've never used a set of the 332 ovals.
horsepower1 is offline
Old 02-23-2016 | 04:53 PM
  #216
Default Is it just me?
Have a nice day!
I have this feeling you were just not being sincere there.
Kinda of a have a nice day while I talk $hit about you on another forum type of have a nice day..
ICDEDPPL is offline
Old 02-23-2016 | 05:05 PM
  #217
F-2 Speedy's Avatar
I really don't think that's bad at all, they do look nice, its all about the improvement over stock to me, bang for the buck spent = hp gained
F-2 Speedy is offline
Old 02-23-2016 | 05:16 PM
  #218
Best investment I ever made in context of over all performance gains! DO NOT under estimate what a professional and I do mean PROFESSIONAL cyl head man can do to enhance your engines power output! Just some real world input from a hobby boater,
abones is offline
Old 02-23-2016 | 05:22 PM
  #219
AFR 335cnc heads.
sutphen 30 is offline
Old 02-23-2016 | 06:12 PM
  #220
Originally Posted by sutphen 30
AFR 335cnc heads.
Wonderful pieces right there, I only wish I had the Cubic inches to use them. more then my little 502s can use!
abones is offline
