HVAC question >
HVAC question
HVAC question
Old 01-23-2016 | 02:35 PM
Not my field here but you mentioned she had no hot water on friday is there a common boiler with heat exchanger for the home? did the city have apipe problem causing brown airiated water.
buck35 is offline
Old 01-23-2016 | 09:23 PM
Tinkerer's Avatar
It is an indirect heater - just a stainless steel tank with a cupronickel coil inside it that boiler water is pumped through. AND I pressure tested the coil. The Air is coming from the bloom.
Tinkerer is offline
Old 01-23-2016 | 11:05 PM
Man, whats going on with the water over there?
you may not be anywhere near flint, but...
buck35 is offline
Old 01-24-2016 | 09:19 AM
I have a low pressure hot water system using radiators and had something similar this year. When I bled it the air coming out smelled like acetylene.
payuppsucker is offline
Old 01-24-2016 | 01:16 PM
Tinkerer's Avatar
The air coming out of a NORMAL boiler system tends to stink especially what comes out of an expansion tank. This was FAR over and above that.
Tinkerer is offline
