mpi and efi intakes?
When i run the numbers thru my dyno program i come up w about 700hp and 640 ft lbs of tq from my 540 combination w good cnc'd afr heads , huge cam and open plenum intake w big throttle body, when i put in the 500efi intake w 1600 cfm tpis tb tq goes up to about 690 and hp goes down to around 650, when i start changing 500efi intake runner length shorter and larger tq goes down and hp goes up, a ported, 500 intake w 13." runners makes more tq in the 4500 area and comes close in hp theoretically , im going to see what happens on my dyno soon. After making max hp from open plenum intake w efi for my baseline im then going to bolt a dominator on that flows almost 1400 cfm and see carbed vs efi what it makes. Then going to bolt stock 500 intake/plenum and tb on. Then bolting on modified upper w azsm 1300 cfm tb, then switching to a plenum w 1600 cfm tpis tb, then cutting plenum dividers out to get runner length down from 15.5" to valve to around 14", then pulling lower and cutting plenum down another 1" to 1 1/2", i would like to see a stockish appearing 500 intake come close to base line numbers which i expect to be around 690/700 hp, will it work, dunno but will be fun!!
Just as further comparison I have a 502 on the dyno right now. Crazy setup, but the customer wanted to mount twin holley throttle bodies on top of the 500 efi intakes. So I did. It's got some Valako ported Brodix BB2+ heads. It's going in a jet boat so the cam I'm using is a little different grind than an I/O cam, but a pretty mild HR. Anyway, guess what HP it made....yep, 625! Just like everyone is saying. Makes over 670 Ft. Lbs. of torque but just quits around 5200 RPM (which I fully expected it to do).
Bob
Bob
Bob
Bob
