Cam selection >
Cam selection
Cam selection
Old 01-30-2016 | 09:43 AM
  #81
Originally Posted by 454captiva
Quote from MT
"Everything is a time constraint. Its like an engine with a very late closing intake valve (more duration per say). At low rpm, it doesnt do well. There is simply too great of a loss of cyl pressure, due to the valve closing so late. However, when the engine is turning high rpm, the late intake valve closing, comes to life!! Why? because the time for filling, or should I say leakage, is reduced."
Is it time for someone to develop an adjustable cam timing solenoid powered system for our ever popular BBC marine builds? This would lessen the need to compromise so much when choosing camshafts around specific parameters.
I agree with this 200%
The first thing that needs to be done is develop a cylinder head that has a cam or better yet cams over the head and go from there. Get rid of the lifters and pushrods. Then we can start opening the valves up and making some real power.
Black Baja is offline
Old 01-30-2016 | 11:45 AM
  #82
Mr Maine. Heres a simulation I just ran on my combo. On the left, you have a 240/245 112 Cam. On the right, a 240/252 cam.
What I see here, pretty much backs up my earlier post about the RPM thing. The cam with the extra 7 deg split, only outdoes the 240/245 cam, at 7000+ RPM for power. Up until that point, the extra exhaust duration does nothing. I am going to try the same thing, but with say, stock GM rect port head flow numbers. Keep in mind, this is a forced induction setup, which textbook says you need more exhaust duration/split.
MILD THUNDER is offline
Old 01-30-2016 | 11:56 AM
  #83
Another sim, no changes except for switching to the edelbrock performer RPM head. Which is much closer flow to a stock GM rectangle port head. A little better , but not that much. What changed? Power across the board went down due to the heads. But, the extra exhaust duration, didn't help again, until 7000RPM.
Old 01-30-2016 | 12:14 PM
  #84
Heres a sim of a N/A setup, 9.5:1 , Edelbrock performer RPM heads.
On the left, cam is a 236/240 114 LSA, cam on the right, is 236/245 114 LSA (very similar to 525 EFI cam).
The trend changed. Now, the cam with the wider split, is actually making more power in the 5000-5500 range, with almost no loss in torque anywhere, and holds on quite a bit longer in the upper rpm.
What is interesting, is there were alot of guys 10 years ago, building marine 540's, with afr 315 heads, with crane 741 cams. That combo made darn good power. Everyone used to say, the AFR's 315's ex port was super awesome, and that the 741 cam had too much split, and wouldn't work well. Reality proved otherwise. The cam worked very well, and made good power to 5600-5700 in those combos, and usually 650-675HP. Hardly bad for an off the shelf cam that had mild lift, and easy lobes.
Old 01-30-2016 | 12:41 PM
  #85
Mild, awesome info. So it looks like from these simulations and at least with those heads some extra exhaust duration is more helpful on a NA engine. Let me throw a wrench in, let's say we look at it as running less intake duration to help the exhaust work better? What if you bring up the intake duration to match the exhaust on that last simulation?
Mr Maine is offline
Old 01-30-2016 | 03:52 PM
  #86
Heres something interesting. Cam above, was the combo with
288/296, 236/245 .629/.632 114 LSA cam.
I then used the controlled induction cam software, to spec a cam for that combo, with max rpm of 5700. The cam it spec'd was
293/301, 238/245.5, .606/.634 , 109 LSA.
The controlled induction software, has zero to do with the dyno sim program, separate items. But anyhow, the cam that it spec'd, showed to be an improvement over the 236/245. Note, that the controlled induction cam, is making more power with less lift, and a slightly less aggressive lobe.
236/245 114 on left, controlled induction spec'd cam on right.
Old 01-30-2016 | 06:22 PM
  #87
SB
The 109LSA vs 114LSA on a NA big block in that rpm range can be significant. The 109 winning. Very good tuned exhaust needed. And yes, this is experience from et.mph in vehicles.
SB is online now
Old 02-01-2016 | 11:06 AM
  #88
I have GLM exhaust, BUT I had them extended where the water enters the exhaust evack 15 inches from the center of the Manifold/Block to eliminate reversion. I am currently running 350 sm blocks with a Comp Cam of 236 intake and 242 Exhaust at .050 Lobe Separation is 112 - I would like to step it up! Any help on Cam Selection would be Great.....
27 MAGNUM is offline
Old 02-01-2016 | 11:18 AM
  #89
SB
A lot of cam for a 5.7.
How about more cubes and better heads. Or better heads and less cam duration?
SB is online now
Old 02-01-2016 | 02:22 PM
  #90
Yes, bigger cubes are not an option rt. now. but I am going to AFR Alum. Heads from Dart Iron 202/160 - I didn't think that cam was so big, it doesn't sound that big and I don't have any idle issues.
