Pyro's and O2 sensors >
Old 02-05-2016 | 11:09 AM
Thanks guys for all the info it has helped me a lot
AJ
Warlock98 is offline
Old 02-21-2016 | 06:53 PM
Originally Posted by Young Performance
It really depends. NA engines don't usually have much variance. They are usually within .5 or so. SC engines can get pretty bad, especially if the blower is spinning really slow. Whipple's can be really bad if they spin slowly. It's really only a problem when the engine is in vacuum. Once the get out of vacuum and into boost, they will usually straighten out. I have seen some engines with Whipples that had almost 4 points from one bank to the other. The only way to fix it is to spin the blower faster. Once we went to DIS, it helped a bunch, but it certainly didn't fix it.
Generally, NA engines will be close. I don't think I have ever seen one with more than 1 point difference. SC engines can be bad and certainly need to be checked.
Eddie
Eddie, what brand spark plug are you most pleased with in a low boosted BBC? AC, Autolite racing series, NKG, etc.
C1000 is offline
