Nose cone removal >
Nose cone removal
Nose cone removal
Old 02-15-2016 | 08:11 AM
Default Nose cone removal
Port side drive has a nose cone and I want to remove it. What's the best way not to break something in the process? TRS drives.
Tmaddox4x4 is offline
Old 02-15-2016 | 08:30 AM
Grinder / chisel/ Grinder, Start forward so once you brake through you can follow the cone back and grind away. you will then find out if it was welded or epoxied on
class6 is offline
Old 02-15-2016 | 12:55 PM
It looks like epoxy, there is a crack all the way around. I was wondering how strong it the epoxy, is it similar to JB weld?
Old 02-15-2016 | 02:07 PM
Yes, it probably is. Just go slow. you'll get it off. I wouldn't be surprised if its faster with them off
class6 is offline
Old 02-15-2016 | 04:03 PM
Craney's Avatar
Good thread because I'm going to remove mine to.
Craney is offline
Old 02-15-2016 | 04:31 PM
Full Force's Avatar
I was wondering also, I am using spare drive on starboard with no cone, port drive still has it, also have RPM difference too... hmmm
Full Force is offline
Old 02-15-2016 | 05:26 PM
Which one has more or less RPM?
picklenjim is offline
Old 02-15-2016 | 05:43 PM
Full Force's Avatar
No nose cone has more rpm, but also found 2 spark plugs cracked so that should be the issue, now that I know engines are 3hp away from each other I will see what it does now
Old 02-15-2016 | 05:50 PM
The nose cone produces prop slip, but they look cool. It should be the other way, what type of props are you running?
class6 is offline
Old 02-15-2016 | 05:53 PM
Full Force's Avatar
I was told opposite, that they give prop cleaner water, I am running 25 Mirage plus
