HaxbySpeed
Old 02-21-2016 | 08:28 AM
  #31
F-2 Speedy's Avatar
Originally Posted by Tinkerer
GPM - My 598 should produce 750 HP NA and will produce 1425 with the M4 installed. I don't have a lot of room to the side of the carb now. I don't believe I have the room to get the inlet pipe up into the hood scoop to connect to the hat.
That just blow's me away, add a hair dryer and double the HP
F-2 Speedy is offline
Old 02-21-2016 | 08:35 AM
  #32
I don't think I have the room to use a standard intake and throttle body and still have room for the hat elbow on top of the throttle body.
I feel your pain !
The Extreme Velocity dominator hat is HUGE !
Don't know how I'm going to fit it under my hatch..
Boatally Insane is offline
Old 02-21-2016 | 08:42 AM
  #33
Boost can be your best friend for making power. Check out the air temps. I doubt this combo Dennis Rogers built, had the stock procharger intercooler . I wanna say it had a custom built BIG intercooler from Dave at Wesco.
File Type: pdf
MILD THUNDER is offline
Old 02-21-2016 | 09:01 AM
  #34
Tinkerer's Avatar
Mild Thunder
My 598 is basically the SAME engine is Dennis Rogers using the same M4 Procharger. I am just going to run it NA for at least one year. The limiting factor with it in NA is the intake manifold and Holley HP 950 carb. With a bigger intake and carb it would probably produce more than 750 HP.
Tinkerer is offline
Old 02-21-2016 | 08:40 PM
  #35
Tinkerer's Avatar
phughes69 -- why would I need a cam sensor if I am running a degree wheel? Also the engine has a solid roller cam - will a knock sensor even work?
Tinkerer is offline
Old 02-21-2016 | 09:34 PM
  #36
Cam sensor is only if you want to run sequential fire. If you run waste fire, you only need crank sensor. You can run waste fire setup with LS coils, I did it. Alex told me no advantage to running sequential on a marine motor and only makes install more complicated. I ended up just using a Mallory oil pump drive plug where my distributor used to be.
Gimme Fuel is offline
Old 02-22-2016 | 07:08 AM
  #37
Tibbstoy2's Avatar
Ditto on sequential fire vs. waste fire not having a significant advantage... I've tried it both ways and both provide clean burn and the same power results on the water (tested on the same day). I am running with the cam syncs installed, but I just unplugged the wire to keep the system simpler (using the Holley Crank Trigger with DIS coils).
As far as kits, they can save you a ton of money. The issue for you is, most of them come with the throttle body - but I'm not sure that's an issue. I went with the universal retrofit kit (Holley 550-500). I confirmed with Holley what parts come with it, at the time, the kit saved me almost exactly $800 per engine and I didn't use the fuel rails they provided. The ECM, throttle body (if you use it), rails, injector bungs, billet regulator, Wide Band O2 and harness, sensors, Power Harness, Main Harness, and injector harnesses included - along with some smaller parts too. It still allows you to buy your injectors, fuel pump, etc...
I guess the question I would have is if you're only planning to run for a year or so NA, you may want to keep things simple and run the Holley 1000 CFM throttle body. The rating is based on dry flow and will out perform or at worst, match a Holley 950 HP. Like you said, your intake will be a potential restriction anyway. The Holley TB is billet and is a really nice piece. I planned to try the FAST higher flowing ones and the 1000 has been so good overall I just can't justify it. So since the Holley 1000 CFM TB comes with the kit, and sells separately for $560, you're better than getting it for free. Try it and sell it if you don't like it.
I did the 556-101 DIS kit on mine... and couldn't be happier. By the way - I'm not sure why you're listing the 556-111 as well, the 556-101 comes with coils, harness, and complete crank trigger kit... it works awesome and has been used on high performance daily drivers on the Holley Forums for several years now without complaints.
I'd double check with Haxby on the Holley Billet fuel pumps, from what I've been hearing the one you have listed (12-890) is actually really doing well compared to the older Holley pumps. Obviously how close to the fuel pump you mount it, how high relative to the tank (pressure head), whether you use a helper pump, and how it's wired will play into the life of any pump. Mine are going strong after 3 years... so I'm not there yet myself.
My $.02
Tibbstoy2 is offline
Old 02-22-2016 | 07:39 AM
  #38
Sequential allows you to trim your fuel between the cylinders for better distribution. It also allows trimming of the spark advance per cylinder. With the new V4 Holley software both of these variables are custom table configurable.
kvogt is offline
Old 02-22-2016 | 02:30 PM
  #39
yschmidt's Avatar
Originally Posted by ACrooks69
You've specifically had problems with the inline and dominator pump or the older gearotor style? I have the dual motor dominator pump and its worked very well for the past 4 or 5 years. What's nice is the dual pump fits nicely on the old Cool Fuel bracket that hangs off the motor mount.
Specifically:
160 GPH Dominator In-Line Billet Fuel Pump
Street/Strip Carb or EFI Applications Supports up to 1600 EFI or 1800 Carb...
Part# 12-1600
yschmidt is offline
Old 02-22-2016 | 02:41 PM
  #40
GPM
Originally Posted by yschmidt
Specifically:
Part# 12-1600
At what PSI
GPM is offline
