Cost to paint hull sides >
Old 02-22-2016 | 08:06 PM
vintage chromoly's Avatar
Originally Posted by murfman
I just bought a gallon of Diamont in Dodge PR4 Bright Red to paint my truck today, it was 1000$ for the gallon, 1560$ for the paint, 2 quarts of House of Kolor tinted sealer, 1 Gallon of reducer, and a gallon of clear.
Red will always be the most expensive pigment.
White is a different story.
Also, ppg 2021 clear is 225 a gallon.
vintage chromoly is offline
Old 02-22-2016 | 08:58 PM
My estimate is $ 8-20k depending on the amount of prep work, number of colors, # of mask and fade work. If you show some pictures of what you like to a couple of boat painters, you will get a lot closer than estimates on OSO....including mine.
BenPerfected is offline
Old 02-22-2016 | 09:12 PM
Originally Posted by ezstriper
you could also consider using the color change wrap vinyl, it's a colored material, clear coated designed just for that, we have used it many times with great results...
I've heard a lot of great results with this. Wondering if it's transparent at all? Anotherwords what if your trying to cover a boat with outdated light to medium color painted graphics and you just wanted to cover in white etc. I would imagine you still need a smooth surface either way.
getrdunn is offline
Old 02-23-2016 | 12:11 PM
Originally Posted by Got Cigs
ezstriper, thanks for the info. if the time comes, I may have to look into that. Any idea what the cost is? thanks.
comes down to what has to come off, all thru hulls that are in the way, lights etc, customer wants us to do a 38 fountain SF has several thru hulls that need to come out and he is saying impossible to get to now to remove, so we are held up on that, material is 5' wide and that works with most boats about 70 colors at this point...
ezstriper is offline
