Dominator preference
#101
BCK I get what you are trying to do, would be nice to see your different carb and intake combo power difference. problem is on here there a lot of experts that always chime in to tell you what you are doing wrong but never have any real world dyno numbers of there own to compare what you are trying to do. only tell you what you are doing wrong, what wrong cam you have in, your wrong heads, your choice of intakes suck, the dyno you use sucks and so on. thanks for trying to compare carbs.
#102
Did you get around to running your 540s with the 325s and madera cams yet ? What kind of power did they make?
#103
The summary was:
Swap a cam + 15 hp
Swap a intake + 10 hp
Swap a carb + 10 hp
Add a spacer + 5 hp
Add another spacer + 5 hp
Straight bottoms and flat decks
#104
you are correct there are some good points made you just have to read between the lines a bit. I am close to being complete, took a little more time because I don't have an open check book. builder has motors about 2 weeks from being complete. then off to dyno. just got complete ignition, still up in the air with carbs, I have 4150's with merlin intakes and have a set of 1050 dominators with no intakes? guess I will leave it up to Brad Nickerson to send him the 1050"s before the motors and buy new intakes or go with the 4150 and intakes I have? it will be his call on price vs gain. thanks for asking MT.
#106
#107
Unfortunately I couldn't test different 4500 intakes as I was just using what I could borrow. I just tested a 4150 Vic Jr vs a 4500 Victor. I think I picked up 10 hp and a decent amount of tq by putting the 4500 on top of the 4150 Vic Jr. It's all posted in a couple threads on here.
#109
#110
